Samsung UN46EH6000 LED ERROR Codes
+ More Options
Latest Activity
  • Michale32086
    replied
    Re: Samsung UN46EH6000 LED ERROR Codes
    Originally posted by tom66
    They mean nothing. It is not an error code.
    Most likely open circuit LED strip, or short circuit LED to chassis.
    Yea, that turned out to be the problem with a previously mentioned Westinghouse I worked on..
    OK, disassembly it is...
    I don't think that's a factory cut.......
    Well, it WAS until I spliced it to see if that was my problem..
    Yea, probably not the smartest move, I realize...
    Thanx for the response...
    replied
    That will cause a Samsung to cycle the power or fail to boot.
  • Michale32086
    started a topic Samsung UN46EH6000 LED ERROR Codes
    I have a nice UN46EH6000 that I have tried 3 different power boards on. All three produce the same response.
    When plugged in, I hear the SAMSUNG tones, but absolutely no light on the screen at all..
    On the power button (a PS3 style thumb button) a red LED blinks 6 times..
    I was going to tear down the unit to the bare bulbs and see if the problem lies there but before I do, I wanted to see if those Error Code Blinks mean anything else.. GOOGLE was no help..
    Also, on the cable between the power board and the video board, there is a trace that had been factory cut...
    Any hints would be appreciated...
  • Curtissimo
    HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
    by Curtissimo
    Hi everyone.
    I have a HP Elitebook 850 G8.
    Serial: 5CG2324XM0
    ProdID 6L8D5EC#ABA
    It has a Winbond W25Q256JVEN Chip.
    I need to remove BIOS Password.
    I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
    Attached my dump.
    I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
    I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
    What I did:...
    08-26-2025, 04:42 AM
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • peterwang
    Samsung NP750QGK-KG3US BIOS program error seeking help
    by peterwang
    PCB:BA41-03025A BA92-25486B
    I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
    08-14-2025, 08:15 PM
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    The TV does not turn on, the standby indicator is on. All voltages are present.
    Emms is dead. Not readable, not detected.
    Replaced emmc.
    But with another dump there is no launch
    Terminal log
    UART
    AC_ON
    RPMB key is not yet programmed
    HASH1_VERSION=0x00000000 64bit
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0...
    06-01-2025, 02:11 AM
