Re: Samsung UN46EH6000 LED ERROR Codes
One shorted mlcc cap can make the ones next to it read short too, maybe take the first one in the row that reads short out and check it out of circuit, recheck the others see if they still read short, lots of times it's only one bad cap, video example there, I've seen others too, this is the one I found in English: https://www.youtube.com/watch?v=jLd6QO7Z7m4
I know this is old post, but still, if any one finds it like i did, i found the issue (not the solution yet).
I have a UE48H6200 with the same issue, sound no image no backlight, Cause? Short in the rigth panel board (i dont know the name, the one between the tcon and the panel).
If i connect one flat cable from the tcon to the panel at a time i get backilight but no image, when i connect both, no backlight at all.
Measuring the componentes i found on the right board some ceramic capacitors shorted, gnd to 2 lines in each buffer line.
Dont know if its one buffer shorted or a cap going short.
Probably will try to inject 1V to both sides of one of the caps and see if anything heats up, but im inclined to be a buffer line gone bad...
So sad, great tv, what a waste. Ill post if i find out any solution other then new panel.
Cheers.Leave a comment:
I used 46" SAMSUNG LED backlights with broken screen as the light source in my garage, it is also good for light table.Leave a comment:
Yea, lesson learned.. I thought I was careful with them, but I had a houseful of grandkids... So it's likely I wasn't concentrating enough..
Ah well, like I said. Lesson learned..
Hopefully, it's like leaving the boat plug out of your boat when you put it in the water..
It's a mistake that only happens once...Leave a comment:
Oh dear, that sucks. LCD panels are very delicate, so you must be careful to avoid damaging the tab bonds.Leave a comment:
Well, unfortunately a sad ending.I got in the new LED strip.. I tore down the TV again and installed the strip.. When I went to put on the actual picture glass, I had torn one of the cellophane connectors completely off the glass..
I didn't handle that very well and ended up sweeping a million glass shards off the floor..
So, this one was a bust.. But, at least I have a working set of LEDs... At least I think they are working.. The TV might have been slammed down on the counter a few times.. things are a bit fuzzy...
Anyways, thanx for the assists.. At least I learned alot..Leave a comment:
That simply re-enforces my hope that, once the replacement comes in, I should be able to get this puppy up and running..
Thanx again..Leave a comment:
OK, found a wall wart that did not blow anything up... It's rated at 12v, but the meter says it was putting out 16v..
Referring to the attached pic..
I touched the 16v to the points indicated by the boxes...
On the Green points, all the LEDs to the RIGHT of the box lit up fine.. The LEDs to the LEFT of the box did not light up...
Except for the one red box on the right. No LEDs lit up at all...
Touching the 16v on all the boxes on the left.. No LEDs lit up...
Apparently, the one strip on the right side is bad.. Just to confirm, I pulled that entire strip off and tested them individually. Still no joy..
But I find it hard to believe that all the strips on the left are bad..Leave a comment:
It's worth noting there is no difference between "LED" TVs and LCD TVs, they both have LCD panels, but one has LED backlights and other has CCFL backlights.
Picture wise, virtually no difference (maybe slightly brighter), energy saving is better.Leave a comment:
I seem to remember from the LCD laptop display that there were like a half dozen different mylar sheets. That's what frustrated me so much about that...
In this latest project, there was the glass display, a single mylar sheet and a think white plastic diffuser and that was it..
Well, I'll tackle an LCD next and see
Thanx again...Leave a comment:
It's roughly the same.
The only real difference is there are fluro bulbs in the panel instead - these are quite thin and can potentially be damaged if you are careless.Leave a comment:
One thing that this project (and the Westinghouse project before) taught me was that breaking a TV down to it's bare components wasn't nearly the horror I thought it was going to be..
But then it hit me today..
These were LED TVs. My only experience before was with LCD laptop displays and those were a nightmare..
How does breakdown of an LCD compare to the breakdown of an LED??
Anyone have any firsthand experience??Leave a comment:
CCFL and EEFL bulbs contain a SMALL amount of mercury. About 0.02g per TV. Eating three tuna sandwiches releases more mercury into the environment than a 32" TV contained.
Actually LED TVs are better environmentally because they require less coal power to operate... more than any mercury saved from the bulbs!
I am convinced far more damage is done to the environment by dumping ~15kg of electronics, metal and plastic, than a few milligrams of mercury ever would, or even considering the extra power used by the display.
True, but here in the states things we do never really make sense, rest of the world thinks we are crazy!
You are right about the power consumption LED/CCFL.
Give me a plasma any day of the week! If I am going to drive a car its going to be a flashy gas guzzling machine of beautyLast edited by Shinju; 12-10-2014, 02:19 PM.Leave a comment:
I am convinced far more damage is done to the environment by dumping ~15kg of electronics, metal and plastic, than a few milligrams of mercury ever would, or even considering the extra power used by the display.Last edited by tom66; 12-10-2014, 01:49 PM.Leave a comment:
^ one would think, I believe the huge push for manufactors to go LED is environment preservation CCFL and EEFL are pretty toxic.
Wonder if those LED shields are causing them to die premature due to best capture?Leave a comment:
Great news, how are the other LEDs, any of them showing brown tint for the heat?
It is so sad that the LED is supposed to be an improvement from CCFL which required high voltage to operate, but they cut down on the LED design by not using proper heat management, so many of these TV with LED backlights are failing a lot.Last edited by budm; 12-10-2014, 01:47 PM.Leave a comment:
DING!!! DING!!!! DING!!!!
I think I found the problem.
A big black burn in the middle of one of the LEDs on the right side half-strip that didn't function..
So, we now why THAT one doesn't work..
Like I said above, I am going to operate under the assumption that the left side strips are good, I am just missing something on powering them up...
Replacing one half-strip is going to run me about $25.. Worth it if I only have to replace one..
Not so much if I have to replace 7...
Anyways, thanx again... I'll follow up when the replacement comes in..
EDIT: Is there a trick to snapping these LED covers back into place??Last edited by Michale32086; 12-10-2014, 01:18 PM.Leave a comment:
Unfortunately, my little redneck battery tester thingy is not very reliable... I am going to dig around my shop tomorrow and see if I can find a 3V wall wart to use..
Until then I am going to operate under the assumption that I, at the very least, have to replace the one right side half-strip...
Thanx for all the help and replies.. Even if this doesn't pan out to fixing the TV, I learned a helluva lot..
And THAT'S a win, no matter how ya slice it...Leave a comment:
by CurtissimoHi everyone.
I have a HP Elitebook 850 G8.
Serial: 5CG2324XM0
ProdID 6L8D5EC#ABA
It has a Winbond W25Q256JVEN Chip.
I need to remove BIOS Password.
I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
Attached my dump.
I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
What I did:...-
Channel: BIOS Requests ONLY!
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
by peterwangSamsung NP750QGK-KG3US BIOS program error seeking help
PCB:BA41-03025A BA92-25486B
I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
by AK_777Hi everyone!
I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and... -
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
The TV does not turn on, the standby indicator is on. All voltages are present.
Emms is dead. Not readable, not detected.
Replaced emmc.
But with another dump there is no launch
Terminal log
UART
AC_ON
RPMB key is not yet programmed
HASH1_VERSION=0x00000000 64bit
E-B
FDE enabled
layout pattern onebin by SAR7,0... - Loading...
