Samsung UN40D6400UFXZA Power Cycles
  • twilliard
    • Aug 2014
    • 29
    • US
    My Samsung UN40D6400UFXZA Power Cycles (click on and off) you can just see the smart TV logo show then turns off, TV Keeps cycling
    Power Board PD46b2_BDY Code: BN44-00427B
    HELP!!
  • twilliard
    • Aug 2014
    • 29
    • US
    Re: Samsung UN40D6400UFXZA Power Cycles
    No bulging capacitors
    • tibimakai
      • Jan 2012
      • 3680
      Dose days are gone, when capacitors were the fault.
      I'm thinking mainboard.
      If do you disconnect the wire harness between power supply and mainboard, the TV turns on and has backlight?
      • twilliard
        • Aug 2014
        • 29
        • US
        When I unplug the wire harness between power supply and mainboard
        You can hear a relay click one time( does not cycle) but no backlight
        • twilliard
          • Aug 2014
          • 29
          • US
          link to video of tv power cycling
          https://www.dropbox.com/s/mx3zqa7j6c...53728.mp4?dl=0
          • twilliard
            • Aug 2014
            • 29
            • US
            Link above bad
            New updated Link
            https://www.dropbox.com/s/60gjk19uqf...53728.mp4?dl=0
              Inspect the power supply board real well, especially the solder joints of the transformer legs and the legs of the MOSFETs and Diodes mounted on the heatsinks.
              Also list the DC Voltage readings of each pin with its name of the connector CNM802, there is a chart that lists the pin out of the connector, check them when TV is plugged in but power switch is not activated, and when the power switch is activated.
              • twilliard
                • Aug 2014
                • 29
                • US
                Main Board unplugged reading taken on Power Board
                Pin # Label Voltage My Reading
                7 ---- 13V --- 12.77
                9 --- 13V --- 12.77
                10 --- 13V --- 12.77
                17 --- 5v --- 5.33
                18 --- 5v --- 5.33
                19 --- 5v --- 5.33
                  Do you see a pin marked "BL ON" or "ON/OFF"? Check that too.
                  • twilliard
                    • Aug 2014
                    • 29
                    • US
                    PIN LABEL My readingPIN LABEL My reading
                    2 PWM4 0 1 OD_LE 2.68
                    4 PWM3 0 3 OD_ON 3.16
                    6 PWM2 0 5 GND 0
                    8 PWM1 0 7 B13V 12.77
                    10 B13V 12.77 9 B13V 12.77
                    12 BLU 2.89 11 Vamp 12.77
                    14 GND 0 13 Vamp 12.77
                    16 GND 0 15 GND 0
                    18 A5V 5.33 17 B5V 5.33
                    20 PS 4.11 19 B5V 5.33
                    • twilliard
                      • Aug 2014
                      • 29
                      • US
                      PIN__ LABEL__ My reading
                      1__ OD_LE__ 2.68
                      3__ OD_ON__3.16
                      5__ GND__ 0
                      7__ B13V__ 12.77
                      9__ B13V__ 12.77
                      11__ Vamp__ 12.77
                      13__ Vamp__ 12.77
                      15__ GND__ 0
                      17__ B5V__ 5.33
                      19__ B5V__ 5.33
                      2__ PWM4__ 0
                      4__ PWM3__0
                      6__ PWM2__ 0
                      8__ PWM1__ 0
                      10__ B13V__ 12.77
                      12__ BLU__ 2.89
                      14__ GND__ 0
                      16__ GND__ 0
                      18__ A5V__ 5.33
                      20__ PS__ 4.11
                      • tw2005
                        • Oct 2011
                        • 6458
                        Looks the same fault as a 55D7000, defective LED strips. Could be mainboard but I know with mine i proved open cct section of strip. Mine had a 4 channel LED cct, none blown but suspect joints. Disconnecting the backlight leads on mine created the same relay cycling. managed to bypass the LEds broken and it ran for 6 hours then I think they were burnt out.
                        Just for info, I have lttle experience with LCD.
                          OK, pin 20 PS (PS_ON, 4.11VDC), is it steady or it is fluctuating in sync with the power cycling?
                          Do you also hear the power relay RL801S clicking in sync with power cycling?
                          This TV has 4-channel LED driver circuits.
                          Did you check the solder joints on the bottom side of the board? see the red circles in the picture.
                          I also marked the bottom side of the board to show the function of each section of the board based from what I can see from the picture provided by shopjimmy.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            To me, it seems like on the right side, the LEDs don't turn on.
                            • twilliard
                              • Aug 2014
                              • 29
                              • US
                              OK, pin 20 PS (PS_ON, 4.11VDC), is it steady or it is fluctuating in sync with the power cycling? -- fluctuating in sync
                              Do you also hear the power relay RL801S clicking in sync with power cycling? -- YES
                              Did you check the solder joints on the bottom side of the board? see the red circles in the picture.-- Yes Re-Soldered All
                              I found this on the main board
                              1) what is it
                              2) is it bad (does not look good to me)
                              Thank you for all the help trouble shooting this
                                OK, so the main board is sending out Pulse on the PS_ON line instead of steady DC.
                                Is the V5B and B13V also fluctuating?
                                https://www.badcaps.net/forum/attach...1&d=1417811352
                                That is the small inductor with a hole on the shrink tubing, it does not look burnt out.
                                • twilliard
                                  • Aug 2014
                                  • 29
                                  • US
                                  Is the V5B and B13V also fluctuating? Yes in Sync with the clicking
                                  • twilliard
                                    • Aug 2014
                                    • 29
                                    • US
                                      OK, now it makes more sense now, the standby power supply is not stable, it can be due to bad caps on the power supply board or the main board is drawing too much current.
                                      You can run the power supply board by itself and use the 10 Ohms 5W resistor to simulate current draw of 0.5A on the V5B output, it should be able to maintain 5V output with 10 Ohms load.
                                      • twilliard
                                        • Aug 2014
                                        • 29
                                        • US
                                        I do not have a 10 Ohms 5W resistor is there anything else I can us
                                        sorry I am new to this!!
                                        • valvashon
                                          Samsung UN55FH6030: random power cycling
                                          by valvashon
                                          Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                                          About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                                          Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                                          10-20-2023, 09:59 AM
                                        • high-tech
                                          Samsung UN55F7050AFXZA ver. TD01 power cycling
                                          by high-tech
                                          Hello everybody, I could use some help on this one... It's got me guessing...
                                          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                          9. ground (PWM2) 10. 0.9 volts cycling...
                                          09-15-2020, 03:39 PM
                                        • reessi
                                          HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                                          by reessi
                                          I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                                          It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                                          What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                                          I have checked these lines in diode mode and they seam normal -> 600.
                                          I have checked to see if they come on for even a fraction of a second...
                                          07-15-2025, 09:14 AM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
