Technika 22" TV screen goes blank after 2 seconds
  • YeOldeGinge
    • Nov 2014
    • 30
    • Telford and Wrekin
    My Technika 22" x22/14c-gb-tcd-uk TV has a problem.
    While the TV is on standby if I press the power button the standby light turns from red to orange while it starts up then green as the screen comes on after 2 seconds the screen goes blank and the light remains green.
    I have checked the capacitors in on the power supply and they all seam fine so what do you recommend me to check as I really can't think what it is
    If you could get back to me it would be really helpful
    This is a link to a video showing you what happens sorry if its a bit dark it was quite late
    Link: https://www.youtube.com/watch?v=E0tS...ature=youtu.be
    Ryan
  • selldoor
    Slow Learner
    • 7870
    Re: Technika 22" TV screen goes blank after 2 seconds
    Please can you update your profile with Country and Mains voltage.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      He'll be in the UK if he's got one of Tescos finest!!
      It'll be the CCFL tubes in the display-panel 10-1....
      Common fault on these cheap crap things
      TELEFIX
      • selldoor
        Slow Learner
        • 7870
        Yes well I could have guessed that but I dont want someone normally working with 110v
        to tell him to set his meter on 200vAC further down the thread.
        It could also be a transformer out on the inverter board or the crap capxon caps thereon.
        • YeOldeGinge
          • Nov 2014
          • 30
          I've updated it I live in the UK and how would i go about fixing these CCFL tubes then?
          • vinceroger69
            • Mar 2012
            • 6714
            can you upload pictures of the boards used in your tv ive fixed a set like this a while ago it was the inverter transformer at fault once we see what parts are used we can get you to carry out some tests etc have you got a multi meter?
            • YeOldeGinge
              • Nov 2014
              • 30
              Ok I will upload them in like an hour wont take long
              • YeOldeGinge
                • Nov 2014
                • 30
                Here are the Pictures of the bored...
                • YeOldeGinge
                  • Nov 2014
                  • 30
                  Its fixed now guys thanks for the support it was a great! :P
                    So what did you do to fix it?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ryan
                      Hey your from telford were you selling this tv on the sales site I am am looking to buy one with the exact same issues as you ?
                      • YeOldeGinge
                        • Nov 2014
                        • 30
                        The TV was fixed by soldering to joint between the CCFL tube and the wire.
                        • Dav83
                          • Apr 2015
                          • Eng
                          I have the same TV with what looks like the same issues. Could you still see a faint dark picture when the TV was switched on?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Hi im Reece I work for Gmc Tv's. We repair all kinds of tvs around Telford and surrounding areas, send me a Pm and we can help if you want ?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              I have Dav83's tv here with me now, this one had the same issue but the lamp was cracked so I used another set of lamps that I had laying around and the tv came right back to life. I will upload a youtube video of the repair.
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • Chrissygizmo
                                Panasonic TX-48CX350B backlights but white screen , blank screen
                                by Chrissygizmo
                                Hi all, I’ve got a problem I hope someone can help me fixi.
                                I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                01-11-2025, 03:18 PM
                              • dicky96
                                HP Elitebook Screen blank - backlights but no image
                                by dicky96
                                Hi guys
                                I'm trying to fix this laptop screen
                                Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                04-28-2021, 07:30 AM
                              • reformatt
                                by reformatt
                                07-31-2025, 08:37 PM
                              • Kalman27
                                Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
                                by Kalman27
                                We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
                                We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
                                I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
                                Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
                                06-17-2025, 05:52 AM
