Element 40 led blue screen problem
  • beeton
    • Sep 2011
    Howdy.
    I have an Element 40 led tv. powers on but has a blue screen with no characters. Screen is uniformely blue so I do not believe the inverters are the issue. None of the buttons work (volume, source). Plugged in an hdmi source and no effect. I do not hav the remote. I have changed the capacitors on the power board but as there was no change (or worsening), I think it is not the power board. Any suggestions? My older RCa had an input issue caused by a tiny fuse that was blown (some inputs, bad audio) but I can't seem to find any other fuses on teh Element except for the main fuse.
    A new one is cheap, around $120 on Black Friday sale so not much point in ordering new boards.
    Any suggestions would be appreciated.
    Thanks.
  • KevinCro
    • May 2014
    • 104
    Re: Element 40 led blue screen problem
    Sounds like a main board problem. Check it for visible defects.
      I would say it is main board problem also.
      I saw the ad for this 40" for Black Friday tomorrow for the same price, so it lasted one year, that is about $120 + tax per year to own this TV.
      • beeton
        • Sep 2011
        Main board meaning the board that accepts the inputs, not the power board?
        I was going to hunt around the main board for any fuses as that may cause a problem with inputs as it did with my RCA. But they are so darn small, may be hard to find. If no fuses, any suggestions apart from looking for bulging capacitors (very small ones on this board and all seem flat)?
        There are only 4 boards on this model: Power board, input board, led inverter board and a small board at the bottom. Not technically sure what it is called.
        And yes, Target featured these for $120 on "Black Friday". Even at $120, not sure TV that craps out in less than a year is a good buy.
        Thanks.
        • Dirty70Bird
          • Jan 2017
          • 13
          • usa
          bump, any updates to this thread? I have 3 Elements with same issue, replaced all 4 boards in 1, and same result.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            please upload good clear pictures of the whole back side of the TV so we can see how all the boards are connected together, then the straight shot pictures of the power supply board and the main board.
            You should look at the connector of the power supply board that goes to the main board, it should have labels to tell you what each pins are for so you can take the DCV reading of each pin to find out what are missing.What is the tv model number?
            • mmccomputer
              problem with replacing lcd screen
              by mmccomputer
              I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
              otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
              If anyone has any information on the subject...
              12-15-2024, 03:44 PM
            • jimjoe123
              LCD TV Green/Pink screen problem
              by jimjoe123
              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
              Then each time...
              02-23-2020, 01:29 AM
            • jean luc ferre
              acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
              by jean luc ferre
              on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
              i tried the hard reset, cmos reset, changing the ram without results.
              in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
              The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
              but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
              11-22-2025, 03:54 PM
            • Chrissygizmo
              Sony KD-55XG9505 lines on screen problem
              by Chrissygizmo
              Hello again everyone,
              This is my latest mission, to try getting this Sony tv back to normal working order…
              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
              02-19-2025, 11:31 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
