Sony Bravia KDL 46hx820 6 blinks
  • waybel
    • Nov 2014
    • 65
    • canada
    #41
    Re: Sony Bravia KDL 46hx820 6 blinks
    been doing that and have about halfway traced back so far from connector and found no voltage yet
    • waybel
      • Nov 2014
      • 65
      • canada
      #42
      Anyone have a cheap power supply and mainboard for this sony 46hx820?
      • tibimakai
        • Jan 2012
        • 3680
        What are the part numbers(on stickers)?
        • waybel
          • Nov 2014
          • 65
          • canada
          #44
          main A1819029A
          power APS-295
          • angel-boy
            • 550
            • Romania
            #45
            I havea a 46HX820 with that getting a 4 blink , i check the ribbon that @freakaftr8 is saying .
            any ideea ?
            • angel-boy
              • 550
              • Romania
              #46
              help ?
              • angel-boy
                • 550
                • Romania
                #47
                • Elecfronicsssss
                  DA0NJJMBAG0 charging light blinks
                  by Elecfronicsssss
                  Laptop motherboard DA0NJJMBAG0
                  PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                  CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                  GUIDE ME WITH THE PROBLEM..
                  SUMMARY-
                  1.NO 1.8VOLTS ON BIOS PIN NO 8.
                  2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                  05-12-2025, 02:32 AM
                • PopsCaps
                  Sony Bravia KDL-40V2500 that will not power on
                  by PopsCaps
                  I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                  I do not hear any sound and I cannot see any backlight.
                  I have tried disconnecting every cable on each board one at a time to see if anything changes.
                  The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                  My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                  03-25-2025, 11:23 AM
                • SkishyIshy
                  Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                  by SkishyIshy
                  Hey All,
                  I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                  I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                  I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                  03-17-2021, 11:44 AM
                • AK_777
                  Sony KD-65A1 Repair – 4 Red Blinks Error
                  by AK_777
                  Hi everyone!
                  I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                  Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                  02-20-2025, 04:15 PM
                • jchon
                  Sony A1e 5-blinks help
                  by jchon
                  Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                  I found the service manual, which was critical to know where to probe.
                  https://www.manualslib.com/manual/20...1e-Series.html
                  With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                  Unfortunately the 5-blinks...
                  06-28-2023, 11:52 AM
