Re: Samsung UN55D6050TF Power Light Blinking
This set is flawless too. No marks older people had it and just said one day it quit.
Im pretty sure I have bad leds. I would try and replace them if I had replacements....Leave a comment:
I have the same problem. When you click Search the box drops down then click Advanced Search from there and a new Search page opens up.Leave a comment:
Thank you. I need all the help I can get. I have like 3 sets open. Working on a 65 the pasg few days wore me out. I had to open a different one to see if I got somewhere with something else.Leave a comment:
fair enough, this guy mmartell has good knowledge with these i feel
https://www.badcaps.net/forum/showth...ight=un55d6000
plenty of hits with un55d6000Leave a comment:
I gathered that just from reading your 10 page thread.Leave a comment:
I tried that and no. I thought the main had to talk back to turn the backlight onLeave a comment:
If your backlight harness has four wires then the easiest thing to do atm is disconnect the cable from power supply to main and plug it in. If your power supply AND baclights are working they will come on and you can probably say your main needs replacing. Report back.Leave a comment:
There's a fair bit to read in that thread i linked , but yes i'm seeing bad main, bad LED strip or possibly bothLeave a comment:
My PSU is slightly different, i can't see a relay in your shots. Mine is BN44-00428
Try a search for un55d6000 in this forum, has the same PSU, backlight, tcon and panelLeave a comment:
Doesn't sound like relay clicking, I can almost not even hear it. I also read that mainboards commonly go on this set also. And if I have to get my hands dirty ill get into the leds....I have nothing to loseLeave a comment:
Is it coming from the PSu the clicking? Does it sound like a relay click?
maybe yours has a single bank of LEDs in series? With mine if the backlight is disconnected it also just clicks.
What pSu part number? looks very similar to mine.
i'm sure you'll get some other opinions shortly. I guess a bad main could do it but I think these have a common issue wit the LEDs burning out or in mine cracked solder.Leave a comment:
Oh and the tickin is very faint. Its not the normal clicking you would hear....Leave a comment:
And why would it continue on and off with nothing plugged into the power supply?Leave a comment:
There is no brief logo on the screen or any flicker of the back light at all....Leave a comment:
Sounds like open cct / failed edge lighting LEDs. I've got a D7000 and basically it's a 4 channel backlight and any led that fails creates an open cct and the TV endlessly cycles on/off relays clicking and brief flash of the screen with the SMART logo.
There's some guys who have done more and posted on other similar models. Some have managed to replace/repair the SMD LEDs, for mine no good, unique and they have them standingon there edge, 2 -3 yr old TV down the tube.Leave a comment:
I have a 55" Samsung with the power light steady blinking. I can here a weird tickin noise on the power supply. I have tested the pins on the power supply and the numbers are bounching up and down. With or without all boards plugged in. I have tried without tcon same results, with out main and tcon, with out backlight, all same results. Even the psu by itself numbers up and down. Here are the pictures....Tags: None
by JRyanSaved this TV from the trash but it will not power on the red power indicator light blinks 6 times with no display. I've attached pics of the power board(1st pic) and mainboard(2nd pic). I don't see any blown caps on pb like I expected so what do y'all think is the issue?...
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by huzoThe board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
I've tried flashing the bios...
interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V... -
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
by russpallHi there,
I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
...2 Photos - Loading...
