Have a sony kdl-52xbr9 with no backlight, will power on then relay clicks and get 13 blinks from standby light. At 12v vcc pins from power supply im getting 3.6 volts way under the 12v needed. So i need to be looking on the secondary half of the power supply for the fault? Can the main board hold the voltage back if its faulty? If I unplug all boards from power supply should i get 12v at pin?
Sony kdl-52xbr9 13 blinks standby light, no backlight
Re: Sony kdl-52xbr9 13 blinks standby light, no backlight
If the main board is shorted then the power supply voltages can be low. Also depending on the design of the power supply, a short on one rail can cause others to sag or go missing entirely.
To activate the PSU you should jumper PS_ON to 5V. I like to use a resistor about 100~470 ohms to protect the power board from over-current.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Service manual:
According to the manual, 13-blink is BALANCER D4N, D5 board.
Can we see the whole backside of the TV?Attached FilesLast edited by budm; 11-15-2014, 09:54 PM.Never stop learning
Did you download the service manual?Never stop learning
You can use STBY 3.3V to POWER ON, don't forget to use resistor.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I did downlad manual, thanks for link budm. Jumpering from 3.3v to power on, power supplu made no difference. How does the panel communicate with the main board if its faulty. Voltage should rise to 12v then back off I would think, if fault detected.Comment
No communication from panel, it will detect shorted T-con, no comm from T-con board, or inverter/BLU fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, thanks tom. I get slight rise from 3.2 v to 4.8v with tcon disconnected. Im going to take a look at tcon.Comment
I'd look at power board. If t-con was shorted that would have gone to 12V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That is a diode, it goes across a pair of transformer taps so the outer pins will appear shorted, this is normal.
Do you have an oscilloscope available? Maybe try checking if the output is unstable - could be bad output capacitors.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That is dual rectifier diodes wit common cathode, the two outer pin will show low resistance of they are connected to the secondary winding of the transformer, that is normal. Its the resistance between the middle pin (Cathode) and the two outer anodes that you need to worry about.
If you look at the service manual you will see how it is connected.Never stop learning
Sorry for delay, been out of town. I was able to put a new resistor in place 3.3v to power on on the pcb. I have 12v going to tcon,and other boards now. But still no backlight, same 13 blinks. Another forum mentioned bad ccfl bulb,but wouldnt the screen try to prime before it shutsdown? Im getting no flash of backlight.Comment
Is it possible force the backlights on by jumping the pin? Disconnecting does nothing.Comment
Ok guys, been a while since I looked at this tv, got about 8 high end smart tv's in that required my attention first. Anyhow I am able to jumper bl-on, on the power supply to 5v pin and I can get the backlights to come on. I still getting 13-14 blinks at standby light, number of blinks change every few attempts.Comment
Have you tried to disconnect the ribbon cables from the tcon to the panel? This model was well known for the panel failing (sony even had a extended warranty for this model). If the tv turns on properly with all ribbons removed then try each ribbon until you get the error code. This will tell you which section on the panel is shorted. Hope this helps out.Comment
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
Laptop motherboard DA0NJJMBAG0
PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
GUIDE ME WITH THE PROBLEM..
SUMMARY-
1.NO 1.8VOLTS ON BIOS PIN NO 8.
2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT... -
by noinimodNo standby red light, nothing
This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
Disconnected JK3 power board from main board, checked voltages on all the pin outs
At a few pins I can see the power supply providing 19.5V to the main board
Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,... -
by SkishyIshyHey All,
I have a Sony 65x900f that I purchased cheap because of a no-power issue.
I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate... -
by macinjoshHello all,
My Sony Bravia recently (after a storm) shows no red standby light at all. Taking it apart, I noticed that one of the ICs on the main board seemed to have a hole in it, so I replaced the main board.
However, I still have the same problem.
I've looked at the SONY technical flowchart for these models, but am stuck at what to do at this point. Here's what I've done:
1. I've verified that the power supply board is getting 120v AC.
2. Verified standby voltage, about 3V DC on pin 1 of the power supply.
3. Verified... - Loading...
