Sony kdl-52xbr9 13 blinks standby light, no backlight
  • topfli8979
    • Oct 2012
    • 311
    Have a sony kdl-52xbr9 with no backlight, will power on then relay clicks and get 13 blinks from standby light. At 12v vcc pins from power supply im getting 3.6 volts way under the 12v needed. So i need to be looking on the secondary half of the power supply for the fault? Can the main board hold the voltage back if its faulty? If I unplug all boards from power supply should i get 12v at pin?
    Re: Sony kdl-52xbr9 13 blinks standby light, no backlight
    If the main board is shorted then the power supply voltages can be low. Also depending on the design of the power supply, a short on one rail can cause others to sag or go missing entirely.
    To activate the PSU you should jumper PS_ON to 5V. I like to use a resistor about 100~470 ohms to protect the power board from over-current.
      Service manual:
      According to the manual, 13-blink is BALANCER D4N, D5 board.
      Can we see the whole backside of the TV?
      • topfli8979
        • Oct 2012
        • 311
        I also saw 13 blinks can be faulty panel, hoping not. Figured I should get 12 volts to inverters first.
        • topfli8979
          • Oct 2012
          • 311
          Can I jumper from power supply on to 12v? I don't see a 5v pin.
            Did you download the service manual?
              You can use STBY 3.3V to POWER ON, don't forget to use resistor.
              • tibimakai
                • Jan 2012
                • 3680
                This not a bad CCFL tube? At least on some other Sonys I had this problem.
                • topfli8979
                  • Oct 2012
                  • 311
                  I did downlad manual, thanks for link budm. Jumpering from 3.3v to power on, power supplu made no difference. How does the panel communicate with the main board if its faulty. Voltage should rise to 12v then back off I would think, if fault detected.
                    No communication from panel, it will detect shorted T-con, no comm from T-con board, or inverter/BLU fault.
                    • topfli8979
                      • Oct 2012
                      • 311
                      Ok, thanks tom. I get slight rise from 3.2 v to 4.8v with tcon disconnected. Im going to take a look at tcon.
                        I'd look at power board. If t-con was shorted that would have gone to 12V.
                        • topfli8979
                          • Oct 2012
                          • 311
                          Ok, on power supply secondary side found a fet short 3-leg N9b fch30a04. Shorted across both rear legs, 1and3
                            That is a diode, it goes across a pair of transformer taps so the outer pins will appear shorted, this is normal.
                            Do you have an oscilloscope available? Maybe try checking if the output is unstable - could be bad output capacitors.
                              That is dual rectifier diodes wit common cathode, the two outer pin will show low resistance of they are connected to the secondary winding of the transformer, that is normal. Its the resistance between the middle pin (Cathode) and the two outer anodes that you need to worry about.
                              If you look at the service manual you will see how it is connected.
                              • topfli8979
                                • Oct 2012
                                • 311
                                Sorry for delay, been out of town. I was able to put a new resistor in place 3.3v to power on on the pcb. I have 12v going to tcon,and other boards now. But still no backlight, same 13 blinks. Another forum mentioned bad ccfl bulb,but wouldnt the screen try to prime before it shutsdown? Im getting no flash of backlight.
                                • topfli8979
                                  • Oct 2012
                                  • 311
                                  Is it possible force the backlights on by jumping the pin? Disconnecting does nothing.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    You should post some pictures with the power supply connectors.
                                    You can most likely jumper something like BL_ON with a resistor from STBY_ON.
                                    • topfli8979
                                      • Oct 2012
                                      • 311
                                      Ok guys, been a while since I looked at this tv, got about 8 high end smart tv's in that required my attention first. Anyhow I am able to jumper bl-on, on the power supply to 5v pin and I can get the backlights to come on. I still getting 13-14 blinks at standby light, number of blinks change every few attempts.
                                      • nicholas1110
                                        • Aug 2012
                                        • 127
                                        • usa
                                        Have you tried to disconnect the ribbon cables from the tcon to the panel? This model was well known for the panel failing (sony even had a extended warranty for this model). If the tv turns on properly with all ribbons removed then try each ribbon until you get the error code. This will tell you which section on the panel is shorted. Hope this helps out.
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Elecfronicsssss
                                          DA0NJJMBAG0 charging light blinks
                                          by Elecfronicsssss
                                          Laptop motherboard DA0NJJMBAG0
                                          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                          GUIDE ME WITH THE PROBLEM..
                                          SUMMARY-
                                          1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                          05-12-2025, 02:32 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
