Vizio E552VLE Not Turning On
  • tonelope10
    • Nov 2014
    • 19
    Hello Group,
    My TV is just over 2 years old and for the last 3-4 months its been hard to get turned on, progressively getting worse. It has the orange colored Vizio emblem on the front when not turned on which is correct. When it is turned on all that shows on the screen is the big V on the start up screen. About 1 out of 10 it will come on correctly after a few seconds of the V screen and work perfectly for however long its on, but its becoming more infrequent. Also, it wont turn off without the power being disconnected. We have begun just unplugging it back and forth until it works properly and leaving it off when not in use.
    I have removed the backing and can take pictures this evening and add them if needed. To the untrained eye everything appears normal to me but I know nothing about what I'm looking at. I looked for rounded or bulging resistors and saw none. The one fuse that I found (250v) is not clear, it is a milky color but this could be normal for all I know. Does anyone know what the likely cause could be?
    Thanks!
    Re: Vizio E552VLE Not Turning On
    Yes, we always do need good clear pictures of the back side of the TV and the boards for start.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      BudM seems like the same problem as another person that could not turn off there Vizo TV where after jumping S to D of U21 the picture came on and then something shorted out. If this is the same main bd. it might save time to just go to the input and output and gate of U21?
        That U21 in another thread is for powering the T-CON circuits on the main board. I have no idea what he has on this 55" TV.
        • tonelope10
          • Nov 2014
          • 19
          Please let me know if thesese pictures help. It is a E552VL model.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5036
            • New Zealand
            It's a ceramic fuse, they are white, that's normal. Only clear glass fuses typically change appearance when blown - they usually go black or silver.
            Besides, if the fuse was blown the TV would get no power and wouldn't work at all. The fact that it works sometimes means the fuse is not blown. (Of course, a fuse with a loose fuse holder or such could cause intermittent problems, but that is very unlikely to be the case)
            -David VanHorn
            • tonelope10
              • Nov 2014
              • 19
              Does anyone know what might possibly be the issue?
                Pictures are way out of focus (please look at your pictures, if you cannot read any labels on the board then we cannot read them either), I cannot read the model number on the board or the labels next to the whites connectors on the top right.
                Also need the pictures of the backside of the TV so we can see how all the boards are connected together.
                https://www.badcaps.net/forum/showthread.php?t=39740
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  If you are using a digital camera see if you have a macro setting and switch it to that for close up pictures. Yes, the pictures need to be clearer. BudM It will be interesting to see if it is the same set up as the other Vizo with the same symptom.
                  • tonelope10
                    • Nov 2014
                    • 19
                    I hope these help. My wife is getting irritated with our dismantled TV and this is my only hope haha. I can take more pictures if needed.
                      OK, I found the good pictures of your DELTA POWER SUPPLY 0500-0507-0790 (DPS-321AP).
                      When the TV is not working, you need to verify that you do have >2VDC on the PS_ON pin of CN201 when the power switch is activated. If you do have PS_ON, then check and see if you do have 12VDC on CN201, 18VDC on CN204, 24DVC on CN202.
                      Also report the DC Voltage of A, B, C on CN202 when TV is OFF and when TV is turned on.
                      You should also verify that the backlights are on or not when it is not working, you may have to look at the back side of the panel in the dark to see if they are on. We need to know if you do not see the pictures on the screen is due to no backlights or the T-CON board is dead.
                      http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
                      • tonelope10
                        • Nov 2014
                        • 19
                        I apologize but I am very new to this stuff. I have a volt meter but I'm not sure how to use it to test the areas you are asking. The backlights have to be working because when I power on it goes to the V screen and the back of the TV is all lit. Would you mind walking me through how to test those places you asked about?
                          Do you have user manual for the meter?
                          So you are saying that the backlights are on but no pictures on the screen?
                          • tonelope10
                            • Nov 2014
                            • 19
                            I do, its an E Tek10709. The TV turns on and gets stuck on the opening screen which is a big white V on the screen. If you turn it on and off enough it eventually goes to the HDMI input and works perfect.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              I would concentrate on the meter manual that has to deal with Voltage and Ohms and learn these before you take the measurements. Also, stick to the section of the TV that BudM ask you about as there is other places on the TV that have very high voltage. There are also, videos online that will teach you about the different settings on the meter such as V (AC), V (DC) and Ranges volts, (m) volts, (u) volts. Ohms represented by the Greek letter Omega and ranges, Ohms, (K) ohms, (M) ohms. Good-Luck
                              • ecking767
                                • Oct 2009
                                • 492
                                this sound like an EEPROM problem if your TV is freezing on the "V" logo, does it become unresponsive? and you must unplug the TV to power it off?
                                • tonelope10
                                  • Nov 2014
                                  • 19
                                  Ecking that is exactly what happens! What do I do?
                                  • ecking767
                                    • Oct 2009
                                    • 492
                                    Replace the main board
                                    • tonelope10
                                      • Nov 2014
                                      • 19
                                      Looks like those are $150-$200, not sure if I should just get a new one. Are you fairly certain that would fix the problem?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        It sounds like an EEPROM issue, but I don't see any for sale. So maybe it's not an EEPROM issue.
                                        I would measure the regulators on the mainboard.
                                        I have a E371VL and I have replaced the EEPROM, but did not repair the issue and one of the EBay seller, is selling a kit for this TV and I have found out, that in that kit, there is no EEPROM. There are three regulators and two smd fuses.
                                        The regulators have three pins on one side and a wider one on the opposite side.
                                        http://smg.photobucket.com/user/Simo...F9SMD.jpg.html
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • Arkiered
                                          Vizio E552VLE Main Board
                                          by Arkiered
                                          Hi everyone, I am looking for a schematic diagram for the Main Board to a Vizio E552VLE. I have 5V Stby good and solid, but I get no Pwr On signal. If I jumper 5V to it, the Power Supply has 12 and 24V, but I also get no signal to turn the backlights on. Any help is appreciated, Thanks.
                                          10-23-2022, 05:43 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • Holes Flow
                                          Vizio E552VLE Schematics needed! [no power on]
                                          by Holes Flow
                                          Experts,
                                          Like other posters, I cannot get this behemoth to turn on, nor does the Vizio "off light" illuminate. Bought anther power board-no change.
                                          I have no voltages on any of the connectors where voltage levels are indicated. I have voltage on one side of the isolation transformer, and nothing on the other side-on both boards.
                                          Its becoming obvious that the controller board needs power to send a signal back to the power board, but no juice at ALL gets to the control board. REALLY need a schematic...
                                          trying this way... vBulletin can...
                                          08-27-2022, 03:40 PM
                                        • pedromvu
                                          Vizio M65-E0 not turning on
                                          by pedromvu
                                          Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
                                          The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
                                          Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
                                          The voltages from Power to Main board are as follows:
                                          NC = 0
                                          A = 0
                                          BL_on/off = (Some millivolts, probably considered 0)...
                                          11-18-2022, 12:28 PM
