Vizio E371VL Fixed!
    Re: Vizio E371VL Fixed!
    http://www.shopjimmy.com/vizio-3637-...for-e371vl.htm
    Not in stock.
    You can check the DCV on botn ends of each fuse, should have 5VDC, and the other one should have 12VDC.
    I can see 3 Voltage regulator ICs UP3, UP13, UP14 that you can test the DCV of all 3 pins to see what you have.
    • crxguy89
      • Mar 2014
      • 12
      Not in stock.
      Thanks I will check them tonight.
      The link you had was to a 3637-0782-0150 (6A)
      My board is a 3637-0782-0150 (6C)
      Does that matter?
        I am not sure about the 6A and 6C, that may be the revision number.
        I would try contacting SJ to see what they say about the problem with your board and see what their suggestion will be.
        • crxguy89
          • Mar 2014
          • 12
          How do you test these ICs? Test everything to ground? Sorry not familiar with these
            Meter to DCV in 20V range, Black probe on the chassis.
            Looking at the 3-pin regulator with the big tab on top, left pin = pin 1, middle pin/big tab = pin 2, right pin = pin 3. Report the reading for each pin.
            • crxguy89
              • Mar 2014
              • 12
              ok. so I tested the fuses and they are ok.
              So, Here is what I found.
              UP3
              Pin 1 = 0VDC
              Pin 2 = 0VDC
              Pin 3 = 168 mV
              UP13
              Pin 1 = 0VDC
              Pin 2 = 0VDC
              Pin 3 = 168 mV
              UP14
              Pin 1 = 2VDC
              Pin 2 = 3.3VDC
              Pin 3 = 5.2VDC
              I am not really sure where to go from here. I am guess that the readings UP3 and UP13 are not good. If you have any suggestions from here that would be awesome.
                You may not have Voltage on UP3, 13 until the rest of the power supplies are turned on.
                • crxguy89
                  • Mar 2014
                  • 12
                  Is there anything else. i can check? Or is replacing the board the only next option?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    budm do you think a faulty eeprom may cause these issues?
                    http://www.ebay.com/itm/Pre-Programm...MAAOSw9N1VjaBu
                    • crxguy89
                      • Mar 2014
                      • 12
                      Might give it a try because its cheap. Would love some feedback before ordering.
                        From SJ:
                        IMPORTANT:
                        These main boards can have multiple failures, in addition to the EEPROM.
                        If EEPROM replacement does not repair your board, there are likely additional problems.
                        Symptoms EEPROM replacement CAN fix:
                        - Display is frozen on VIZIO logo screen*
                        - TV won't power on with remote/buttons when plugged-in (VIZIO is lit in orange, but won't turn to white)
                        - TV turns on when first plugged-in, but it won't turn back on after 30 minutes of being off
                        - TV shuts off and goes back to standby mode (orange VIZIO lit) after you turn it on
                        Symptoms EEPROM replacement CAN NOT Fix:
                        - TV turns on but has NO backlight
                        - TV turns on AND backlights are on, but has no video display at all
                        - HDMI issues
                        - Audio issues
                        Based on the info, it does not sound like you have EEPROM problem.
                        • captainKKK
                          • Sep 2018
                          • 287
                          I have a good PS board with correct voltages and a Vizio371VL 3637-0652-0150 main board. when power is plugged, shows the bottom orange VIZIO emblem, then pushing the power button on the side turns the bottom VIZIO emblem white, at the same time the backlights start flashing. It stays this way until you push the power button again with the input button, release and press the power button again makes it turn off and displays the orange emblem again. Any ideas? Is this a eeprom problem?
                          • BeFreeTech
                            • Apr 2018
                            I have the same E371VL TV with the same problem you describe: 12v and 5v appears on the power supply. When powered on the visio standby logo goes from amber to white, and I get a limited series of about 8 backlight flashes while hearing a ticking sound from the area of the main board. Shining a flashlight on the display reveals no image. I can turn it off and the Visio emblem returns to amber. Power it up again and the sequence repeats.
                            • howardc64
                              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                              by howardc64
                              Failure Symptom
                              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                              Where is the short?
                              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                              05-27-2025, 02:56 PM
                            • otaku_nut
                              Vizio E701i-A3 fixed but now has red vertical line
                              by otaku_nut
                              Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                              08-19-2025, 06:11 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • tmhobadcap
                              VIZIO M60-C3 Can the vertical line be fixed?
                              by tmhobadcap
                              I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
                              02-05-2023, 03:37 AM
                            • mrtek
                              Vizio M65-C1
                              by mrtek
                              Hi.
                              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                              07-14-2025, 07:28 PM
