Panel used in multiple models - Interchangeable parts?
  • ulsh72
    • Apr 2014
    • 28
    So I'v traced a problem with a Vizio E550VL to needing a new main board. $160 - Ouch.
    The MB is the type that has the built in TCON. After some research, I found that there are several other models that use the same LC550WUB-SCA1 panel and have the integrated TCON. Notably the E551VL and E552VL whose mounting points and components pretty much all line up the same.
    Opinions? Should (Will) this work?
    Has anyone ever tried it?
    Suspected interchangeable MBs listed below:
    ORIGINAL Vizio E550VL (LASPHCAL):
    PANEL:LC550WUB-SCA1
    Main Board:
    3655-0152-0150
    CSD: 3655-0152-0395
    Compatible E550VL Replacement:
    3655-0072-0395R
    3655-0072-0150
    Alternate E552VL (LATPKIBM, LAQKKICM):
    3655-0352-0395R
    3655-0352-0150
    3655-0352-0150R
    Alternate E551VL (LASPHCHM, LASPHCHL):
    3655-0332-0395R
    3655-0332-0150
  • ulsh72
    • Apr 2014
    • 28
    Re: Panel used in multiple models - Interchangeable parts? -YES!
    I am happy to report that this DOES work!
    I was able to use a 3655-0352-0150 from a Vizio E552VL in a Vizio E550VL.
    All functions work, all inputs, digital and analog work, and I gained network connectivity from the upgraded board! All I had to do was dremel holes for the extra ports on the back cover.
    • mmartell
      • Oct 2013
      • 3189
      Nice! And the board was cheaper I take it ?
      • ulsh72
        • Apr 2014
        • 28
        YEP! Original board is $170, and I got the newer model board for $90.
        The model upgrade took it from a dumb TV, to a smart TV with apps and internet!
        • fixitelectronix
          • Nov 2013
          • 18
          3655-0332-0150 from the E551VL works....just tried it myself. This thread helped me find a cheaper alternative and i appreciate it. Wanted to report my findings
          • Iuproud
            • Jul 2015
            I also have an E550vl that was having many issues (all of my HDMI's had quit working, remote would only work sometimes, then it quit turning on. (I still had orange backlight, but wouldn't turn on.) I began reading forums and this seams to be a common problem... (just switch out the main board)...however, I couldn't find the E550vl main boards..all out of stock eveeywhere. I read this forum and decided to try this upgrade. I bought a main board for an E552VL and installed it very easily ($115 on ebay). I did need to cut out new holes for a 3rd rear HDMI and a hole for the ethernet cable. I'm happy to say it all works great. My E550VL is also now a smart tv.
            • ulsh72
              • Apr 2014
              • 28
              This is awesome guys!
              I'm glad my experience could help you out!
              • Panacamanana
                • Sep 2015
                I just came into the possession of an E550VL recently that is having the power cycling with clicking noise.
                I am having the absolute worst time tracking down a replacement Main Board.
                I can't seem to find a site that isn't sold out of it. Am I looking in the wrong places? What would you guys suggest.
                I'd like to try to get the smart TV functionality but at this point I'll settle for a functioning TV.
                Thank you in advance.
                • ulsh72
                  • Apr 2014
                  • 28
                  I just set up search alerts on ebay and waited. They are probably getting harder and harder to come by...
                  • Nick's Tvs
                    • Jan 2014
                    • 621
                    I just got a E552VL tv that won't turn on/respond to turn on command. PS-on is present but it acts as if there were no signs of life. Main board 3655-0352-0150
                    Now I have a board laying around, a 3655-0072-0150 from a E550VL which works with the tv, however the board is not a smart and the reason its laying around is because the HDMI ports are all toast on it.
                    Would it be wise/prudent to do some component swapping from the not so smart board onto the smarter board or would I just end up royally screwing up the soft/firmware?
                    Has anyone tried this?
                      • 31196
                      i doubt the firmware would be effected.
                      the biggest risk is you damage something through lack of skill or tools.
                      • Nick's Tvs
                        • Jan 2014
                        • 621
                        STJ
                        No problem then definitely doing it. I got all the hardware skills and tools baby!
                        Will report back and let everyone know if I end up bumping into any issues.
                        • Nick's Tvs
                          • Jan 2014
                          • 621
                          Sorry for the late update but came accross a similar issue, and yes indeed those are compatible. In fact someone else on another thread stated they swapped the main board from a E550VL with part number 3655-0152-0150 to the E552VL 3655-0352-0150 and it worked with proper picture. So all those parts are compatible, the only difference is some of the ports are different and the layout of the board is different.
                          • boyop
                            Are Dell's PS_ID and HP's ADP_ID interchangeable across all models?
                            by boyop
                            Hi All,
                            So I'm trying to get into laptop motherboard repair and am having trouble understanding Dell's PSID issue.
                            According to a site I come across :
                            https://hackaday.com/2014/03/03/hack...dentification/
                            Original Dell adapters use a ds2501 to communicate with the laptop SIO using the '1-Wire' system to inform the SIO of the chargers current rating.
                            The confusion I have is, do the adapters communicate anything other than that? If not, is a single charger sufficient to use across all models that the charger fits...
                            05-20-2021, 11:09 AM
                          • stormanimal83
                            somebody familiar with hasboard repairs? BM1397AD interchangeable with Bm1397AG ? S17+ and T17+
                            by stormanimal83
                            i got myself a complete Antminer T17+ with 3 dead hasboards for a very good price.... for parts i bought S17PRO boards.... i replaced all missing resistors and changed some asics because they were bad... but wihout a tester... i used the miner instead and changed firmware to awesome miner firmware for better and faster diagnoses via miner log and lower fan speed...
                            for my understanding and what i read on the internet these asics should be interchangeable in one chain but in my case i´m getting no more communication to none of the asics on all 3 boards. 2 of the boards weren´t in...
                            04-13-2025, 04:26 AM
                          • Msb1xr
                            Have to turn on 77” LG C1 multiple times to get to come on
                            by Msb1xr
                            Have to turn C1 on and off multiple times for it to fully come on
                            Have to run LG C1 on multiple times for it to fully work
                            If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
                            Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
                            10-13-2023, 04:09 PM
                          • nicktasios
                            Troubleshooting Apple Multiple Scan 17 Display
                            by nicktasios
                            I recently picked up a Quadra with a Apple Multiple Scan 17 Display. The Quadra was not working, it clearly had corrosion from leaking caps so I replaced them and luckily it chimed and worked properly.
                            The next problem to tackle was the screen. Sometimes it turns on and off multiple times before finally turning on, and then it sometimes turns purple. After waiting some time, without doing anything, it regains all colors. Another symptom is that it sometimes seems to momentarily blink.
                            Also, not sure if this is related, but sometimes, after experiencing these problems,...
                            09-17-2023, 03:51 AM
                            GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
                            65 Watt Multiple Output Global Performance Switchers
                            Condor Part Summary
                            • 65 Watt Wide Range Input
                            • High Efficiency (Up to 90%)
                            • Universal input 90-264 Vac
                            • 2-year warranty
                            • Also available in single outputs
                            • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
                            • Exempt from line harmonics standard EN61000-3-2
                            • Commercial Approved to UL1950, CSA-C22.2 No. 950,
                            • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
                            10-07-2024, 05:46 AM
