Have to turn on 77” LG C1 multiple times to get to come on
  • Msb1xr
    • Oct 2023
    • 5
    Have to turn C1 on and off multiple times for it to fully come on
    Have to run LG C1 on multiple times for it to fully work
    If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
    Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture. Have to do this 4-20 times before it comes on fully.
    Red status light comes on and off.Sometimes screen is completely blank sometimes whiteish lines appear on the sides. Change how many there are and how far they go across.
    Any ideas on what's causing this issue?
  • Diah
    • Feb 2013
    • 6564
    Re: Have to turn on 77” LG C1 multiple times to get to come on
    yours LG C1 OLED TV ?
    • nomoresonys
      • 12330
      • U.S.
      Yep, LG C1 is oled.
      • Msb1xr
        • Oct 2023
        • 5
        Yes it is
        • Diah
          • Feb 2013
          • 6564
          try reset it via service remote with ( IN_STOP )
          • Msb1xr
            • Oct 2023
            • 5
            Remote came yesterday did this and still the same issue when I tried to turn on this morning.
            • Diah
              • Feb 2013
              • 6564
              its time to upload high resolution focused photo for yours power boards from up & down side
              • Msb1xr
                • Oct 2023
                • 5
                Can you explain what you mean by up and down side? Guessing front of board and back of board?
                Attached example pic of what I think you need. This is not a pic of my board.
                • Diah
                  • Feb 2013
                  • 6564
                  Man, what should i do with yours example photo ??? LOL... print it and to put on wall.. LOL
                  i need yours Original boards... take it out from the set.. and upload photo of the top side and down side,,, so i can explain to you how we test the power boards as stand alone,,,,
                  trouble shooting OLED should start from Power boards
                  • Egidio85
                    Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                    by Egidio85
                    Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                    the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                    the fan does not start.
                    I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                    any advice on what to check?
                    06-10-2025, 05:00 AM
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • brusli009
                    Multiple motherboard wont turn on (wont spin psu fan)
                    by brusli009
                    So i got multiple motherboards that wont do anything when i short the power button on them
                    1. B660 Gaming X DDR4 that i took out the bios chip (suspecting it was bad cuz the cpu/dram light would keep flickering). Put it back on after seeing that i cant use the ch341a to program it. Now it dosent turn on when shorting the button, but the qflash turns it on.
                    2. Asus Z370 E Gaming that was having some ddr4 slot problems, also took out the bios chip and updated it via the ch341 but it wont start, power led is on.
                    3. Asrock H87 Pro4 not turning on at all, nothing done to it....
                    09-07-2023, 01:53 PM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
