Sanyo DP40142 No backlight
  • keithdisco
    • Apr 2012
    • uk
    #41
    Re: Sanyo DP40142 No backlight
    i know its an old post but i totally agree very bad design i would never buy one of these pos tvs
    i found exact same issue as above blown resistor
    with burnt connections between led strips
    new name is toss-shita
    • RAMSELECTRONICS
      ATARI boy
      • Jul 2015
      • 48
      Hello all, I think it is new post for now, I am talking about the power supply from DP40142. I checked the voltage the 5V is working fine, I see the 12V and 24V are group and does not give output. I replaced the chip SSC9512S and no luck.
      I tested with 2 of MOSFET are fine.
      Any one know about this? please help. THANK YOU!
      • RAMSELECTRONICS
        ATARI boy
        • Jul 2015
        • 48
        I forgot to add this, the power supply is FSP140-4F01
        • Shane711
          • Dec 2014
          • 493
          I am surprised to see Herbssat's picture of the LED driver board inside the panel. I have never seen a circuit board inside the panel like that before. I have this TV, it seems to be turning on but no back light. I will have to disassemble the screen to see if I have this same problem.
            https://www.badcaps.net/forum/showpo...4&postcount=18
            • Shane711
              • Dec 2014
              • 493
              Thanks budm, that is a very good picture. I found the LED driver board. This is the first time I have seen it in this location.
              Seems my LED driver board is good because I only have 2 LED strips working. Got to leave for a while and when I get back I will remove the bad LEDs and replace them with good ones.
              • Shane711
                • Dec 2014
                • 493
                This Sanyo DP40142 is a piece of junk, man they don't make them like they used to. It looks like I am going to have to replace 80% of all the LEDs, I would say then that they are all bad. Looks like I have no choice but before I do all this work I am going to turn the TV on again with a light behind the screen just to make sure the LCD screen is good. No point doing all this work for nothing.
                • Shane711
                  • Dec 2014
                  • 493
                  Well, good news. The TV is fixed. I had to replace 2 LEDs but I thought I was going to have to replace all of them because 2 strips were bright and the other 3 were very dim. But I put it back together without the screen and the LEDs were very bright. So then I put the TV all back together and it seems to be working good. Time will tell. I have included a picture.
                  Once again this web site has helped me fix a TV because I thought for sure it was the main board. I best keep reminding myself these LEDs love to burn out.
                    Thanks for the follow-up on the repair.
                    What LEDs did you use for the repair?
                    So far to me the TVs with LED backlights seem to have 90% failure due to failed LEDs.
                    • Shane711
                      • Dec 2014
                      • 493
                      I have a bunch laying around that I removed from TVs with bad panels. So I had some that looked almost exactly the same. I used my small heat gun work station to remove them. I then touched up the solder on the TV strip and replaced 2 LEDs on the strip next to the LED driver board.
                      It pays to keep parts laying around. I do my best to keep the parts organized but it's not easy.
                      • Hartman
                        • Oct 2014
                        • The Netherlands
                        #51
                        R053 is not 85 ohms but the smd code is 05B which is 1k1 ohm (1100 ohms)
                        I just repaired my Philips 40pfl3208 which uses the same panel.
                        In my case no backlight and R053 was 7kohm instead of 1k1
                        I also saw that the connecors between the ledstrips made very poor contact.
                        You will have to bypass all of these in order to repair it, so that it is reliable.
                        The led driver passes its power onto a green strip, that transfer it to the horizontal positioned led strips.
                        I also bypassed these connectors in order to make it reliable.
                        Greetings
                        Jeroen Hartman
                        Cctv technician
                        Netherlands
                        • Shane711
                          • Dec 2014
                          • 493
                          Same exact TV as in post #47 & #48. The TV again burnt out some LEDs but this time I noticed burnt contacts on the strips and maybe this short was causing the LEDs to burn out. Seems to only happen on this one strip. So I soldered on some jumper wires to bypass the connectors and the TV lives once again. So far no problems with the LED driver board.
                          • EGM
                            • Sep 2017
                            • 6
                            Newbie here. I've got a similar problem on a Sanyo DP40142 TV. Backlight driver board SSL400_0D5A REV:1.0 I'm not having any luck on tracking schematics for this TV or board. It has a burnt resistor on R005 and as normal, I cant read the value. Can anyone lend me a hand trying to figure this one out or is there a way I can figure out the resistance? I've tested the leds and the only thing looking bad at this time is that resistor. Something burned it up and I'd like to track it down but need some help.
                            • EGM
                              • Sep 2017
                              • 6
                              Shane771 You wouldn't happen to have this BLD board laying around?
                              If you do, can you tell me the resistor number on R005?
                              Thanks for your time.
                              • Shane711
                                • Dec 2014
                                • 493
                                Yes, I have the board and I will get it open sometime soon because I have to repair the LEDs AGAIN! I will get the number for you. The same TV has burnt out LEDs for the third time. The same TV that I fixed in post #47, #48, & #52.
                                Does anyone have any ideas on how I can prevent the LEDs from burning out?
                                  Did you turn down the Backlights level for all input modes?
                                  • Shane711
                                    • Dec 2014
                                    • 493
                                    Yep, I did. Could it be power surges?
                                      May be checking the LED flowing through the LED string to see what you get. The replacement LED rated at about 400 mA or so?
                                      • Shane711
                                        • Dec 2014
                                        • 493
                                        budm, I really need to understand this, I just got another TV that was out by the trash, Very nice clean and brand new looking Samsung 46" and so I will start a new thread on that. 50% of the LEDs are burnt out.
                                        If I fix it with the same LEDs then it will only go bad again.
                                        So if I use LEDs with a higher amperage will that mean they will require more power? If they will have the same brightness but could handle higher work loads that would be the thing to do.
                                        And then I will have to figure out where to buy them.
                                          Do you have the specification of the replacement you are using?
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • DanPoka
                                            by DanPoka
                                            02-15-2025, 05:05 AM
                                          • Comp_Pro
                                            No Backlight Macbook A1990 820-01041
                                            by Comp_Pro
                                            Hello all,
                                            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                            Tests performed:
                                            There is no backlight even with a good screen.
                                            Backlight IC is receiving the correct support voltages.
                                            Fuse F8400 ok
                                            Current sense resistor R8400 ok
                                            Backlight IC is receiving 3.3V on enable pin.
                                            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                            Backlight IC receiving 5V from PP5V_G3S
                                            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                            05-06-2024, 10:23 PM
                                          • cheebster
                                            iPad Pro 12.9 5th Gen Backlight Issue
                                            by cheebster
                                            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                            Anyone...
                                            05-20-2025, 09:17 AM
                                          • canadaboy25
                                            LG Flatron 24EN33TA No Backlight When Cold
                                            by canadaboy25
                                            I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                            I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                            03-07-2023, 12:23 AM
