Vizio E320VL - No Power, No 5v Standby - DEAD PSU??
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Vizio E320VL - No Power, No 5v Standby - DEAD PSU??
Q706
R710=10.5 ohms
R752=11.6 ohms
R701= .200K ohms
D751= .210K ohms
Q707
R759=9.1 ohms
R713=8.1 ohms
R704= .200K ohms
D755= .208K ohms
Q708
R723=3.63K ohms
R756=3.63K ohms
R707= .200K ohms
D753= .835K ohms
Q709
R726=6.37K ohms
R762=6.36K ohms
R711= .200K ohms
D753= .835K ohmsComment
2nd one up and the 2 resistors across from itComment
Looks to me that the resistors for the Blown Q706, 707 are also damaged.Q706
R710=10.5 ohms
R752=11.6 ohms
R701= .200K ohms
D751= .210K ohms
Q707
R759=9.1 ohms
R713=8.1 ohms
R704= .200K ohms
D755= .208K ohms
Q708
R723=3.63K ohms
R756=3.63K ohms
R707= .200K ohms
D753= .835K ohms
Q709
R726=6.37K ohms
R762=6.36K ohms
R711= .200K ohms
D753= .835K ohms
You should be able to read what are printed on the top of the resistors which will tell you what they should be. You show D753 twice, I would removed those resistors, diodes for Q708, 709 and test them off the board. I will not be surprised that they are damaged.Never stop learning
BTW, The reading on Q706, 707 are taken with the MOSFETs removed?Never stop learning
Sorry the Q709 diode should be D757.
All the mosfets are still in place on the board. Should I remove all 4 then recheck them and remove all the resistors and diodes?Comment
I would remove those two MOSFETs (Q706, 707) that tested bad first, but you should also read the numbers as printed on top of the resistors to verify the resistance.Never stop learning
Wow those are hard to read(tiny). I believe they say
Q709
1007
681
2000
Q708
1002
681
2000
Q707
681
1002
2000
Q706
1002
681
2000Comment
1007 is more likely to be 1002?
I expect the resistor connected directly between the Gate and the Source pin to be around 10K (1002).
It is going to be hard to verify the value when they are on the board since there are other components connected in parallel with the resistor you are trying to measure.
If you remove all 4 MOSFET, then you may be able to do comparison readings.Last edited by budm; 12-17-2014, 05:45 PM.Never stop learning
Ok thanks Budm for all your help. I will remove them and check them tomorrow.Comment
I removed the 4 mosfets and did a resistance check on all the resistors and diodes still on the board and I rechecked the mosfets once I removed them and this is what I got.
Q706
1-2=14.6
1-3= .5
2-3=14.0
R710(1002)=.636K
R752(681)= .636K
R701(2000)=.200K
D751=.836K
Q707
1-2=9.7
1-3= .4
2-3=9.4
R713(1002)=.636K
R759(681) =.636K
R704(2000)=.200K
D755=.836K
Q708
1-2=OL
1-3=6.60M
2-3=OL
R723(1002)=.636K
R756(681)=.636K
R707(2000)=.200K
D753=.836K
Q709
1-2=OL
1-3=6.98M
2-3=OL
R726(1002)=.636K
R762(681)= .636K
R711(2000)=.200K
D757=.836KComment
Does it appear that Q706 & Q707 are bad? What would be a good replacement for these KF5N50's?Comment
Q706, 707 are bad for sure.
The resistance will be tough since the Gate drive transformer winding is basically in parallel with the resistors, the only sure way is to remove the resistors and test them off the board, I would remove the resistors for Q706 first since we know that Q706 is damaged, if the resistors tested OK then more likely the resistors for the Q707 will be OK too.
Q708, 709 are not shorted out so the resistors and the diodes are probably OK.Never stop learning
Ok I will take the resistors off of Q706 and get back to you.Comment
Q706
R710(1002)=10.00K
R752(681)= 6.80K
R701(2000)=.200K
Well these appear to be good,Should I remove the diode also?Comment
681 should be 680 Ohms.
http://www.resistorguide.com/resistor-smd-code/
http://www.marsport.org.uk/smd/res.htmNever stop learning
I did find a good replacement for the cement fuse F601 ICP250/3A00SMT = TWW5JR15E but I cant find the equivilant to the 4 KF5N50's.Comment
http://www.shopjimmy.com/kec-kf5n50d...tor-3-pack.htmNever stop learning
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by x_orange90_xI have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
Assuming...7 Photos -
by funkmunk3yHello!
I was given this Vizio because it would freeze up after a few minutes of operation. There were no obvious burns marks or failures. When I was checking the power supply - I slipped & shorted it (tiny crackle & spark) at one of the 12 volt pins - now the entire board is dead & has NO standby voltage @ the connector to the main board.
The fuse at the power input is reading good - the main caps are reading in the 160's & all the diodes read good except one (D9103 - pictured) - but it only reads bad in circuit - I pulled it & it tests o.k.
by Andreas_deHello!
i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
...2 Photos04-12-2025, 10:38 AM - Loading...
