Vizio M65 C-1 power supply dead - NO standby voltage
  • funkmunk3y
    • Nov 2020
    • 22
    Hello!
    I was given this Vizio because it would freeze up after a few minutes of operation. There were no obvious burns marks or failures. When I was checking the power supply - I slipped & shorted it (tiny crackle & spark) at one of the 12 volt pins - now the entire board is dead & has NO standby voltage @ the connector to the main board.
    The fuse at the power input is reading good - the main caps are reading in the 160's & all the diodes read good except one (D9103 - pictured) - but it only reads bad in circuit - I pulled it & it tests o.k.
    There doesn't seem to be getting power to the cold side of the board anymore...
    Any help, direction or what/where to test would be greatly appreciated - Mike
    [IMG][/IMG]
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vizio M65 C-1 power supply dead - NO standby voltage
    Check R9201 (0.1 ohm) resistor.
    Power supply within this pdf
    https://www.electronica-pt.com/esque...6.1e-la-69941/
    • funkmunk3y
      • Nov 2020
      • 22
      Reading 0.4
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        That would appear to be OK.
        So you have no secondary voltages at all; no standby voltage?
        R9841 looks like one of the legs is not soldered in. It could be just the photo?
        • funkmunk3y
          • Nov 2020
          • 22
          No standby - no 12v, no 24v - nothing seems to be making it to the cold side.
          GREAT eye though - R9841 was missing solder on 1/2 of the pin.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            What voltage do you have across C9141 (VCC) and also across R9102 (BNO) at switch on.
            • funkmunk3y
              • Nov 2020
              • 22
              R9012 = .51 dcv
              c9141 = 0.0 dcv
              • R_J
                • Jun 2012
                • 9583
                Check R9113, if ok, then check the values of R9137, R9138 & R9139
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  If there is no voltage across C9141 then there is no supply to run the IC9101 and therefore to switch mosfet Q9101 to power transformer T9101 to provide the secondary voltages.
                  My error - the resistor to check the voltage across was R9102 not R9012
                  Can you check the voltage across C9109 and C9103 at standby and switch on.
                  • funkmunk3y
                    • Nov 2020
                    • 22
                    No - my bad - it was the 9102 - i mis-typed it as 9012...
                    • R_J
                      • Jun 2012
                      • 9583
                      Are you using hot ground to check these voltages in the primary? If you are using the schematic, there are two sets of series resistors coming from point N, check the voltage at point N and then after each resistor in the series. Point V is the startup vcc supply point
                      • funkmunk3y
                        • Nov 2020
                        • 22
                        Again, my bad - the 9141 is reading 00.4 when testing dcv in the 200m setting of my multimeter.
                        • funkmunk3y
                          • Nov 2020
                          • 22
                          R9113 = 00.3
                          r9137 = 14.9
                          r9138 = 14.9
                          r9139 = 18.2
                          • funkmunk3y
                            • Nov 2020
                            • 22
                            Plugged in:
                            C9103 = 4.5 dcv
                            C9109 = .7 dcv
                            • funkmunk3y
                              • Nov 2020
                              • 22
                              Unplugged:
                              C9103 = 0.0
                              C9101 = 0.0
                              The longer I held it there the lower it went... same for plugged in but climbing up.
                              • funkmunk3y
                                • Nov 2020
                                • 22
                                I am not using the schematic - I cannot read one - I am an amateur at best.
                                • R_J
                                  • Jun 2012
                                  • 9583
                                  Originally posted by funkmunk3y
                                  R9113 = 00.3
                                  r9137 = 14.9
                                  r9138 = 14.9
                                  r9139 = 18.2
                                  One end of R9139 should connect to one end of R9113, is R9113 ok? it should be 5R1Ω
                                  • funkmunk3y
                                    • Nov 2020
                                    • 22
                                    R9113 reads 3.5Ohms
                                    • R_J
                                      • Jun 2012
                                      • 9583
                                      R9139 = 18.2
                                      Is this Dc voltage? what are you using for ground?
                                      Check the resistance between J934 (this is one end of R9139) and C9109 + and then to R9113
                                      • funkmunk3y
                                        • Nov 2020
                                        • 22
                                        Yes, DCV - I was measuring across from solder joint to solder joint
