I was just given this 40 LCD super thin LED tv. I brought it home and first thing I did was test the external brick power supply. it has the proper voltage and when I plug it into the tv. I get a red light on the digital audio out. but it does flicker a little. I get a red led just under the middle center bottom of the tv. that stays lit for about 2 seconds and then goes out. about another 30 seconds and the red led lights up and stays lit. when I search on the web it talks about a EEPROM. could that be all that is bad. does anyone have a service manual on this unit so I can test some of the voltage regulators. the front touch panel that turns on and off the tv and changes inputs and channels does not make any changes. thanks for your help.
WestingHouse UW40TC1W wont turn on
Re: WestingHouse UW40TC1W wont turn on
Sorry, no manual, but here are a couple things to start with:
I can't tell for sure with the first picture, but one of the caps in the top right cluster looks like it might be rounded (bulged) on top. Look closely at the top of all the caps throughout the set and see if there are any that are rounded instead of flat on top, or, misshapen in a any way.
Then, do a thorough visual inspection of both sides of all the boards.
Finally, look for connectors that list the various voltages and see if those voltages are present during that two-second window when you try to power it up. Keep in mind that many sets will only allow a few failures before they go into a state that doesn't even do the two-second test. You may need to totally disconnect the set to reset that count.
This should give you a couple places to look, for now. Maybe someone else will chime in soon to help. -
There is two connections on this board that talk about voltage one is 5 volt and one is 12 volt both of them say they are to the T-Con. I tested both of them and they are both correct. I removed each one of the ribbon cables that goes to the LED Back light and I still get the same result. I did have the tv Red led turn off once when I touch the turn off on the front of the TV. but would not turn the red light back on. I get nothing else no backlight, no sound and the only other light is coming from the SPIF digital sound. Looks like all of the controls are touch no buttons. I have added some better pictures. thanks so much for your help.Comment
I am now back on this tv to see if I can figure out a fix or just sell it off to someone else that wants to give it a shot at repairing it. I looked at several other LED posts and found that I should be getting more than the 19 volts dc on the LED drivers. I am looking at a Q38 part number 9980gh 15216G it has the 19 volts on the center pin but nothing on any of the other pins. I will replaced this part and see what happens.Comment
On the Westinghouse I repaired (different model 39") the front LED is red in Stby and turns blue when on. It had bad Led's in it also.
The LED output connector had 26v when in Stby and would jump to around 85v before LED fault shut it down.Comment
So this tv has an external Brick power supply that puts out 19 volts. The power buttons are not real buttons. They are touch sensitive. When I try to turn the set on I get nothing but the solid red LED. So I am thinking that the tv is not getting the signal to turn on. I have tested each ribbon cable all connections to ground and I am not getting any shorts. So I am hoping that rules out LED's shorting out. I will do some more searching and see if I can find some information on manually getting the tv to send the turn on signal.Comment
I am thinking about purchasing a 32" board and testing voltages so I can understand where the voltages should be for the LED's. Does anyone know what voltage I should have that would feed the LED's. The two caps are rated at 100v each.Comment
I think there is some kind of short on the board. when the tv is plugged in I get the solid red light. This tv has touch controls for turning the tv on and off. when I touch the power to turn on the light goes out. the main processor on the board gets hot enough that it is un comfortable to touch. when I test voltages I think I am getting all the correct ones except for the led circuit. I am only getting 19 volts across the caps that are rated 100v.
Originally posted by electronicsurplusWhat seems to be the problem? No backlight? or, on only for a second?Originally posted by ntehicksdo you have any manuals or boards for this model tv?
The problem is most likely one of the LED strips shorted
You can determine by removing of the connecting cables to one of the led strips should be one on each side and try powering on try each side
This set usually suffers from actually the shorted ribbon cable going from the Main Board on the end side of the LED strip due to overheating and melting the coating causing short
If this works please post in forum please either way so it will help others also We do have all boards and Tom66 most likely has manualsComment
Any luck with your WestingHouse UW40TC1W?
I have the same problem....Red LED comes on usng the front panel touch-on/off control...LED backlight comes on (faint dark blue) but no picture.
Pic#1 - TV set off
Pic#2 - TV ON (faint blue light), LED red power light remains on
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... - Loading...
