Panasonic TH-L47ET5A
  • JohnML1975
    • Jul 2025
    • 59
    Hello Forum
    This TV has flashing red standby light
    when i press power the backlight comes on and goes off three times before staying off and back to flashing red light
    during these phases the stanbdy light turns green
    i found the status wire, between psu and led driver board has 3.3V
    So i cut this wire and earthed both sides to ground
    now the TV works
    I shall upload photos
  • JohnML1975
    • Jul 2025
    • 59
    • JohnML1975
      • Jul 2025
      • 59
      I suppose an LED has a problem but from I can tell the backlight appears equal lighting all round
      Shall try to test with an input image video on HDMI
      sharing incase this helps someone else
      • JohnML1975
        • Jul 2025
        • 59
        needs LEDS, you can see the dark patch
        shall pull apart and replace with new
        • JohnML1975
          • Jul 2025
          • 59
          Hello all
          I replaced with new LED strips and the dark spot remained
          So I would have to assume this is a panel problem
          Have thrown the TV out
          Thought I would update since I was unable to repair
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4498
            • Italy - Milan
            Them could be a bar connector problem, a burnt one
