HP Deskjet 3720 power light flashing and LCD with all icons flashing as well
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Hello all need some help, I've got a Deskjet 3720 that turns on but everything is flashing, power light and everything on the lcd also is flashing. There's no paper jams or anything like that, printer is clean inside
  • esqmooo
    HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
    by esqmooo
    Hello everyone.
    This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
    Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
    Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
    I tried long pressing on the power button, after several seconds it would go off then when the button is released...
    03-11-2025, 03:57 PM
  • learnmore
    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
    by learnmore
    Hello Community!
    CASE DETAILS
    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
    Tried inserting firmware on USB and left it in for a few hours, but no change
    03-03-2024, 09:49 AM
  • CraigR
    Hp Spectra x360 Power light flashing, component id
    by CraigR
    Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
    05-07-2025, 11:06 AM
  • stephonwhyte
    un65tu7000fxza - Flashing Red Power Light
    by stephonwhyte
    un65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
    Thanks for all responses.
    11-22-2022, 12:03 PM
  • GRANDGG
    LG 42lw4500 flashing red light , wight light , 2 clicks
    by GRANDGG
    Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
    05-09-2025, 12:27 PM
