  • iglitare
    • Oct 2017
    • 3
    • germany
    Or is it always a bad/shorted panel?
  • tiki66
    • Jul 2016
    • 45
    • Croatia
    99% a bad/shorted panel. Do a tape fix
    • Diah
      • Feb 2013
      • 6403
      show please yours screen how it look
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4396
        • Italy - Milan
        Hi, are you from Albany? The fault is probably a shorted capacitor on the panel strip board, left side, on the AVDD line (15v line).. check it first with ohm meter without power, i say to you the rest later..
        • iglitare
          • Oct 2017
          • 3
          • germany
          I can take pictures as soon as i am at my brothers house again (it´s his TV).
          But it was just grey lit. With left cable from tcon to panel disconnected it was half ok, other half grey lit.
          Thanks for this info, i will check it! Unfortunatelly no, i am not from albany.
          thats what i feared. I will try tape fix after i measured the cap Davi mentioned.
          Before i try the tape fix, is there any way to determine what pin is shorted (measurements with multimeter or oscilloscope)? Or even blow up the short with overcurrent so that is just a open line?
          And if i try the tape-fix, what lines should i tape?
          I would guess the pins towards the center of the pcb where all the traces go to the big chip (left side pin 80 and lower)?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4396
            • Italy - Milan
            I thought so because of your nickname Igli Tare football player..
            first i think you have bad cap, i'm convincted because otherwise you saw the half screen white not black, apart this if it would be the common fault with the tape "cure" , i feed doubts about the technique of the "short" killer, because i think the fault could not be a short in gate drivers, but a current deficit..
            • iglitare
              • Oct 2017
              • 3
              • germany
              Hillarious :-) but i am just an old fan of him since he played in a team i like
              ok, that seems plausible, i will check in a few days if there is a shorted cap
              Sorry, i tried to understand this sentence.
              Do you mean taping does no work (reliably)?
              Where are the gate drivers? directly on panel, unaccessible? Or on the small board of the Panel that holds the connectors to the tcon?
              And where and why and what would be the current deficit?
              • ivtv1
                • Oct 2016
                • Bulgaria
                These pins are always at the end of the tape.
                https://www.youtube.com/shorts/3jD2pe_qUEE
                • KYBOSH
                  Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                  by KYBOSH
                  Previous owner said TV just went blank one day.
                  They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                  Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                  The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                  There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                  I just downloaded the Sony KD-75X7800F Service Manual and...
                  11-19-2024, 10:12 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • ronni
                  Sony KD-43XE8005 with sound, backlight, no picture
                  by ronni
                  I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                  When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                  Removing the LVDS cable results in...
                  12-01-2022, 08:44 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
