Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
  • nomoresonys
    • 12305
    • U.S.
    Probably just the usual short in the panel right, tv heats up short messes up display.
    • iglitare
      • Oct 2017
      • 12
      • germany
      You mean a short in the panel itself, or on a capacitor at the small board on the underside of the panel?
      • nomoresonys
        • 12305
        • U.S.
        Well you can check those boards over, I think you mean the long thin buffer boards but sure it could be in the panel itself.
        • iglitare
          • Oct 2017
          • 12
          • germany
          i can check the caps on the buffer board, will do that again (checked only AVDD line).
          But how can i check for other shorts on the buffer board?
          Where would they usually be? On "data" lines against ground?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4497
            • Italy - Milan
            you can chek for bad diodes
            • iglitare
              • Oct 2017
              • 12
              • germany
              #26
              There was no short that i could meassure. Or i didn´t find it.
              If i tape one specific pin of the 12 datalines in the picture, i have a picture on the TV.
              Problem is, it is flickering if there is motion.
              So that is no solution.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4497
                • Italy - Milan
                #27
                arr there any chips and which on the panel strip boards?
                • iglitare
                  • Oct 2017
                  • 12
                  • germany
                  #28
                  There where some, some ICs, and 2 that looked like diode/resistor arrays. I checked the arrays for short against ground, had none.
                  Could not identify where the line that i taped go to. I am almost shure the line do not go directly to an IC.
                  Since this TV is so big i would have problems to change any chips on the panel strip board anyway.
                  Is everybody sure that a change of the TCON board would not help in this case?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4497
                    • Italy - Milan
                    #29
                    So i camnot suggest a thing because i have no solution ready, the fact that the masked line do not go to those chip doesn't matter for me, i prefer not to explain why, i surely registered a case where the diode packs produced the intermittent fault at the screen.. i have recall of a recent discussion here.. bye.
                    • iglitare
                      • Oct 2017
                      • 12
                      • germany
                      #30
                      So you suggest changing the diode arrays?
                      Sorry if i upset you in any way, that was not my intention.
                      I have no clue what recent discussion you mean.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4497
                        • Italy - Milan
                        #31
                        i suggest to first remove the diodes, test the whole thing, if it works replace them, the other thread is different, i checked , but the diodes behavrd well under a certain load, and bad at another
                        • KYBOSH
                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                          by KYBOSH
                          Previous owner said TV just went blank one day.
                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                          I just downloaded the Sony KD-75X7800F Service Manual and...
                          11-19-2024, 10:12 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • ronni
                          Sony KD-43XE8005 with sound, backlight, no picture
                          by ronni
                          I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                          When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                          Removing the LVDS cable results in...
                          12-01-2022, 08:44 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
                        • Daren87
                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                          by Daren87
                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                          08-13-2023, 03:25 PM
