Vizio E422VA - no picture, logo or backlight
  • SCmaverick96
    • Aug 2015
    • 4
    Re: Vizio E422VA - no picture, logo or backlight
    Originally posted by kaarigar
    Well, I had to buy a new main board and that solved my problem. I bought the main board on Ebay and replaced it myself. I had called the Vizio tech support and they had suggested to fix the problem by installing a new board for $80.
    Looking back I think I should have gone for the official Vizio fix because the EBay board doesn't let me run the Netflix app. Apparently this EBay board was previously used and registered by someone else and I couldn't convince the Vizio to update their database because the serial number was in use by someone else in their database.
    Some have suggested on redoing the flash memory which is ~$40. Can Vizio give a new board for $80 because in that case I may just do that? No boards are presently on Ebay.
    • kaarigar
      Learner
      • Aug 2014
      • 15
      Originally posted by ecking767
      you can clear out the previous customer information by accessing the Vizio menu then: go to help> then clear memory> then enter 0000. this reset the TV back to factory, then you can enter your information if you chose too. the board serial number shouldn't matter to Netflix.
      Yes, I was aware of that and had tried that too. However, the Netflix and other apps such as Amazon Instant Video keep giving the error "Cannot connect". I could never work around that. Any suggestions? BTW, I have verified that the internet settings are correct.
      • ecking767
        • Oct 2009
        • 492
        don't know how you were trying to connect( wired or wireless)
        sometime the WIFI module goes bad. if wired then I can't suggest anything
        • kaarigar
          Learner
          • Aug 2014
          • 15
          I was connecting using the WiFi. The WiFi connection had no problems at all. The diagnostics and rest of the stuff was completely ok. I also confirmed that using the wired network connection.
          • ecking767
            • Oct 2009
            • 492
            What about You tube?
            • sdg001
              • Aug 2015
              I see this is an older thread but I need a main board, too- finding the exact board from my tv is proving impossible are there any others out there that would be compatible?
              • photrix
                • Feb 2018
                • usa
                #27
                Can someone tell me which pins on the power supply connector need to be connected in order to force the ps on to test all the voltages? On a E422VA power supply with the main board disconnected.
                  We need the pictures of YOUR power supply board, the P/N on the board and on the barcode sticker also. There are many version of the board so we want to make sure we get the correct pins.
                  BTW, you should get a couple 470 ~ 1000 Ohms resistors for doing the test, and you will have to disconnect the cable form the power supply board to the main board first before doing the test.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • brad2157
                    Vizio E70-E3 Two white vertical lines
                    by brad2157
                    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                    Replacement main board - Boots up fine, but starting...
                    12-13-2021, 05:11 PM
