Lg 47lm860v 3d tv- no picture
  • Longon
    • Jul 2025
    • 46
    • United Kingdom
    #81
    Originally posted by Davi.p
    Ok, i'm a bit sorry for the rude post, but following certain threads takes so long, too much posts without a single test, i make hard effort to express myself in another language, doing this also when i'm at work, risking accident with the boss..
    reading back the posts, you have 11,6v on the tcon input, this sounds a bit low to me, like a stressing dc dc at valley, then the 3 caps at 0,3v, them are also dirty, clean well them and test the whole tv, if 0,3v still there, remove the 3 caps, one of them can be shorted, if you have a good multimeter, NO 5 euro testers, check ohms slowly across all them, if 0ohms try remove first the one with less decimals measure, check again.. probably tcon is at fault..
    Hey Davi.P....
    I appreciate your humble approach in this conversation. It’s important for us to maintain respect in our discussions. As someone new to this forum and facing mobility challenges, I sometimes find it difficult to get to my workshop area and participate fully. I really appreciate the contributions from all members, as they provide valuable perspectives that help me improve.
    Let’s put this behind us and focus on creating a positive environment where everyone feels encouraged to share. We all have unique experiences that can enrich our discussions.
    After checking your recommendations I will return my findings.
    Long
    • Longon
      • Jul 2025
      • 46
      • United Kingdom
      #82
      Originally posted by Longon
      Hey Davi.P....
      Long
      Hi there Davi.P sorry for not replying sooner, and apologies to anyone else who may of been following this thread... until everything came to an abrupt end, unfortunately have been a little unwell, hence the break.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4498
        • Italy - Milan
        #83
        what type of break?
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
