help with a Philips 47" LCD power fault
    Re: help with a Philips 47" LCD power fault
    OK, the model number is 47PFL7603D, chassis number Q528.2E
    You will have to go to ELEKTROTANYA.COM to see if it has the service manual for this model and chassis (it can have more than one chassis used for the same model).
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      it showed no results for the model but typed in chassis and got :
      http://elektrotanya.com/?q=showresult
      unsure which one to click
        I download this one: Q528.2ELB
        But no diagram for the power suply.
        • vinceroger69
          • Mar 2012
          • 6714
          http://www.ebay.co.uk/itm/FSQ510-INT...item2ecd86ee16
          the link i posted post nine should help you
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            R5 is 120 ohms
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              #26
              thanks guys
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                #27
                i was looking at these http://www.ebay.co.uk/itm/120-ohm-1-...item1c234fd349
                but it looks on the resistor at one side there is a green band ? so they are not the same ?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  looking at post 9 again
                  Brown - Red - Brown - Gold - Green 121 ohm
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    #29
                    thanks vinceroger69 would this one do ? http://www.ebay.co.uk/itm/121-Ohm-1W...item5d4e1e226d
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      pass haha wait for tom or budm to comfirm (im never sure myself when ordering resistors/diodes etc i dont want you to order wrong ones) do you want 50 though.
                      • kasfamily
                        • Aug 2014
                        • 774
                        • Russia
                        #31
                        temporarily for testing, you can use the R4 having the same rating
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          that thread is a bit deceiving in post nine they put the colours up Brown - Red - Brown - Gold - Green which i work out to 12.1 ohm but later says hes replaced it with a 120 ohm and it works i think we need to see what budm/tom66 suggests pity we cant find a psu schematic.
                          • kasfamily
                            • Aug 2014
                            • 774
                            • Russia
                            #33
                            part of the circuit is the same, instead of D101 on your board R5, D101A, B, C, D, F101
                              Do you have the rest of the circuit? it looks like that resistor is connected in series with the Surge Arrestor.
                              • kasfamily
                                • Aug 2014
                                • 774
                                • Russia
                                #35
                                Yes, R4 (and there seems to be R3) on the board of Default themes are connected in series with the arrester. Reduced part of the scheme (psu.bmp) is taken from the downloaded file( page 5) from
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  #36
                                  can anyone confirm what i can purchase and replace >?
                                  • sienoki
                                    sienoki
                                    • Jan 2012
                                    • 314
                                    #37
                                    Hi..ive just picked one these sets up today with smashed screen..psu is working fine..if you dont repair yours id be willing to sell this one
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      #38
                                      how much would you sell for Sienoki ?
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        #39
                                        ok so i got another one of these tvs same model etc all same parts in side and had a look at the PSU and i seen this and was wondering if anyone can tell me how this has happened and if that is likely to be the fault with the other board as the same place where the hole is on this one looks as if its starting to burn on the other board too ????
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • alltvrepairs
                                          Philips 50PUS8555/12 Power supply fault
                                          by alltvrepairs
                                          715ga018-p01-006-003s
                                          Am trying to find a pdf .
                                          i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
                                          tried with meter most components like resistors diodes etc.
                                          in secondary there are no shorts either.
                                          This was struck by a lightning and could see a burn under the air gap capacitor.
                                          Attaching the board.
                                          Any clues welcome.
                                          Tks...
                                          08-30-2025, 08:42 AM
                                        • Biruslapio
                                          Philips 50 Inch 6654 4k display fault
                                          by Biruslapio
                                          Hi, this TV is from the PUG series, had no image, upon using tape to cover the pins on the right side(from the back), it displays only vertical bands that fade away slowly, classic problem with the horizontal part.
                                          There is no short I could find on the panel, when disconnecting any major voltage such as VGH, the T-Con stops pulling down all voltages and I can measure what they should be.
                                          I tried to use an external power supply in place of VGH, as soon as I turned on the tv displayed proper image and then instantly started to fade, T-Con shut down all voltages, it is sensing...
                                          04-10-2024, 11:13 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
