ESR Meter Chart
  • tech2014
    • Aug 2014
    • 807
    ESR Meter Chart
    Hi everyone. I am finding different charts for the ESR meters. Some allow higher resistance and others are lower. I have a tv with only have the screen and found a bunch of caps on the Y SUS board. Here are the measurements:
    10uf 250V=measured 1.90 ohms
    47uf 250v=measured 0.87 ohms
    100uf 160v=measured between 0.79-0.87 ohms
    would these be good ESR or should I replace?
    • 31296
    Re: ESR Meter Chart
    you need to compare the readings to the datasheet for the make & series your testing.
    • mariushm
      • May 2011
      • 3799
      Re: ESR Meter Chart
      The charts you find online are simply informative, with information extrapolated from a few series of capacitors that were popular probably 10 years ago.
      Get datasheet for that capacitor and look up the impedance in that datasheet. If you can't find the exact manufacturer and series, look up datasheets from other brands.
      Those high voltage capacitors are not designed with a particular focus on low ESR, the way they're used in circuit the ESR probably doesn't matter that much.
      For such low capacitances and high voltage, values of 0.3 - 2 ohm would be normal.
      The 10uF 250v may have a bit high esr but it really depends on series and dimensions of the capacitor.
      Throw away the charts, look at datasheets if you're not sure.
      • tech2014
        • Aug 2014
        • 807
        Re: ESR Meter Chart
        thanks guys I will find the data sheets
        • tech2014
          • Aug 2014
          • 807
          Re: ESR Meter Chart
          what site has the data sheets?
            Re: ESR Meter Chart
            What brand of the cap are you looking for? then go to the manufacturer web site to download the info for that particular series of the cap.
            Panasonic has them, and so other major brands as well.
              • 31296
              Re: ESR Meter Chart
              http://www.paullinebarger.net/DS/
              • chth96
                Is it possible to test small ceramic disc capacitor with analogue meter?
                by chth96
                I read EBOOK of Testing Electronic Component and found that
                "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                Is it really possible to test small ceramic disc capacitor with analogue...
                03-09-2024, 10:03 PM
              • narf
                Epson EB-U42 projector / Caps with 0.7 ohms ?!
                by narf
                hi all,
                first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                what i've found so far:
                - the PSU does its job and supplies 12V to the mainboard via the connector.
                - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                - not far away, there's the first cap with a resistance of 0.7 ohms....
                07-02-2024, 03:53 PM
              • Ryan Wurtz
                Lenovo Yoga C740-15IML 5V on usb meter.
                by Ryan Wurtz
                Hello. So I searched and didn't find any posts on this specific problem.
                When plugged in USB power meter reads 5v
                Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                Original mobo had a shorted cpu it seems.
                So I decided I need a new motherboard.
                Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                5v on the meter. Still won't charge. Can still charge the battery...
                Yesterday, 01:08 AM
              • jorpec
                Changing the scale of an analog meter
                by jorpec
                Hi
                I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                I wonder how i can accomplish this so the meter would be precise at any temperature ?
                Thnaks
                01-23-2023, 10:37 AM
                How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                by sam_sam_sam
                About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
