ESR Meter Chart
  • tech2014
    • Aug 2014
    • 807
    ESR Meter Chart
    Hi everyone. I am finding different charts for the ESR meters. Some allow higher resistance and others are lower. I have a tv with only have the screen and found a bunch of caps on the Y SUS board. Here are the measurements:
    10uf 250V=measured 1.90 ohms
    47uf 250v=measured 0.87 ohms
    100uf 160v=measured between 0.79-0.87 ohms
    would these be good ESR or should I replace?
    • 31294
    Re: ESR Meter Chart
    you need to compare the readings to the datasheet for the make & series your testing.
    • mariushm
      • May 2011
      • 3799
      Re: ESR Meter Chart
      The charts you find online are simply informative, with information extrapolated from a few series of capacitors that were popular probably 10 years ago.
      Get datasheet for that capacitor and look up the impedance in that datasheet. If you can't find the exact manufacturer and series, look up datasheets from other brands.
      Those high voltage capacitors are not designed with a particular focus on low ESR, the way they're used in circuit the ESR probably doesn't matter that much.
      For such low capacitances and high voltage, values of 0.3 - 2 ohm would be normal.
      The 10uF 250v may have a bit high esr but it really depends on series and dimensions of the capacitor.
      Throw away the charts, look at datasheets if you're not sure.
      • tech2014
        • Aug 2014
        • 807
        Re: ESR Meter Chart
        thanks guys I will find the data sheets
        • tech2014
          • Aug 2014
          • 807
          Re: ESR Meter Chart
          what site has the data sheets?
            Re: ESR Meter Chart
            What brand of the cap are you looking for? then go to the manufacturer web site to download the info for that particular series of the cap.
            Panasonic has them, and so other major brands as well.
              • 31294
              Re: ESR Meter Chart
              http://www.paullinebarger.net/DS/
              • chth96
                by chth96
                03-09-2024, 10:03 PM
              • narf
                Epson EB-U42 projector / Caps with 0.7 ohms ?!
                by narf
                hi all,
                first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                what i've found so far:
                - the PSU does its job and supplies 12V to the mainboard via the connector.
                - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                - not far away, there's the first cap with a resistance of 0.7 ohms....
                07-02-2024, 03:53 PM
              • jorpec
                by jorpec
                Hi
                Thnaks
                01-23-2023, 10:37 AM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • sarry86
                Hp Elitebook 1030 G1 power issue
                by sarry86
                Hello, I have this Hp pavilion 1030 G1 that starts with a single light on caps lock then it turns off, measurements at the coils, meter in resistance mode (not continuity mode) are as follows: The problem started just after it fell from a desk to the ground. I can't find a boardview or a schematic diagram anywhere, please help me 🙏
                1. 13k ohms
                2. 0.00 ohms
                3. 6.7 ohms
                4. 8.9 ohms
                5. 18.2 ohms
                6. 83.5 ohms
                7. 99.4 ohms
                8. 10.7k ohms
                9. 68.5 ohms
                04-26-2024, 05:54 AM
