Sony KDL-40ex400 LCD tv no power...100% dead
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    #41
    Re: Sony KDL-40ex400 LCD tv no power...100% dead
    for voltage?
    • shelby5041
      • Feb 2009
      • 1505
      #42
      s-d .1v
        That is good, the LED inside the OPTO PH6103 for 'POWER ON' as shown in the circuit should now be on which then turn on the Photo-transistor inside the Opto, so if you check the DC voltage on the pin 3 & 4 of PH6103, it should be <1VDC, this Opto will force the 'MODE' pin2 of IC6301 (CXA3809M) LO. I do not have the spec sheet of that IC, you need to look it up to see how it works.
        • shelby5041
          • Feb 2009
          • 1505
          #44
          thanks i appreciate ur help but im not a tv tech...so this is way above me....prob will toss out tv......all i know is i get no 12v and no 24v on psupply.......at this point its not worth it to me......i would like to learn but i cant have you spend ur valuable time......thank you
          • shelby5041
            • Feb 2009
            • 1505
            #45
            i really just want to know if ps is bad........u guys r too smart.....and i cant understand ur terms...sorry
              May be you can donate it to local electronics training school for the students to learn how to do troubleshooting.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5095
                • New Zealand
                #47
                For the record, I found a datasheet for that IC (see attached)
                According to it, Pin 2 (Mode pin) works thus:
                Mode select input
                (GND connection: Normal sequence
                VCC connection: Standby mode)
                -David VanHorn
                • shelby5041
                  • Feb 2009
                  • 1505
                  #48
                  i work 7days week 12.5hrs day as toolmaker.....and i own 6 rental houses.....my time is so limited.....this was kind of a hobby...i have fixed about 100 lcd and plasma tvs and 40 lcd monitors but most were board swaps or cap replacements.over the past 7 yrs.....but dont do it much anymore ..........im very novice.....
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #49
                    above me sorry.....have no clue what it means
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5095
                      • New Zealand
                      #50
                      What it means is, when the pin has a high input (at Vcc voltge) the IC is in standby mode. When the pin is brought low (to ground) the IC starts up and the power supply is supposed to turn on.
                      -David VanHorn
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #51
                        the ps for this tv is really expensive and so is the mainboard...that tells me its a problem with this model tv......
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #52
                          the ps does not turn on though
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #53
                            shopjimmy sellls a ps repair kit for this tv with 12 compobents and ic6301 is one of them..rest are ic6101,q6301 6302 6303 6304,r6107 6342 6348 ,d6308 ,f6101
                            • shelby5041
                              • Feb 2009
                              • 1505
                              #54
                              i see ph6301 but no ic6301
                              and i see a 12v pin on ph6301 but its 0v when i meter it
                              but like i said have no clue uf that means anything
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5095
                                • New Zealand
                                #55
                                Does Pin 2 of IC6301 go from High to Low when you tell the PSU to start up?
                                PH6301 is an optocoupler, that supplies feedback signal for monitoring the 12v rail, If the PSU is not running there is probably going to be no signal there.
                                The IC you're looking for is in the middle of the board on the bottom side, the big SMD IC, according to those ShopJimmy photos
                                -David VanHorn
                                  Opto PH6103 is the POWER ON Opto, not PH6301.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    #57
                                    i dont see ic6301
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      #58
                                      ok....i c it.....but have no clue where pin 2 is
                                        If you look at the spec sheet, pin one is the one with the dot at the corner.
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #60
                                          so is pin 2 to the right if 1......should i check voltage at pin 2 when i apply pwr on
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • piposarcade
                                            Samsung UN50KU6300 dead no standby led
                                            by piposarcade
                                            01-04-2024, 01:33 PM
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                            05-22-2024, 02:07 PM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
