Sony KDL-40ex400 LCD tv no power...100% dead
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    #61
    Re: Sony KDL-40ex400 LCD tv no power...100% dead
    ok ill check pin 2 voltages rught now
    • shelby5041
      • Feb 2009
      • 1505
      #62
      ok pin 2 on ic6301
      v is .04v when ps plugged in
      v is .04v when pwr on is applied via jumping standby to pwr on pin
        Did you see the dot on the spec sheet, so I am not sure what you mean by "so is pin 2 to the right if 1." To the right???
        You also must use correct ground ref point for the meter since now you are checking the voltage in the primary (deadly side) side of the circuit, you cannot use the chassis for your meter, and do not touch anything in that section! The ground ref point will be the negative leg of the main filter cap C6325. Again, do not touch anything in that section with your hands or body, and do not let the probes slip on you.
          Originally posted by shelby5041
          ok pin 2 on ic6301
          What did you use for the ground for your meter?
          • shelby5041
            • Feb 2009
            • 1505
            #65
            the board is not in tv....im doing this on table...im at work brought board in....ill c if i can do what u said for grounding...nervous now since high voltage side....
            • shelby5041
              • Feb 2009
              • 1505
              #66
              just touched one of the pins labeled ground
              • shelby5041
                • Feb 2009
                • 1505
                #67
                that cap is 450v.....im not sure i should try...im not trained
                • shelby5041
                  • Feb 2009
                  • 1505
                  #68
                  off the subject but i have a pack of new n mosfets i was comparing yesterday while learning.....today my meter is giving me a value of 700 diode setting source to drain and it wont go away...if i touch source to gate with fibgers it doesnt go to nothing.....all of the n mosfets i have are testing that way today.....yesterday source to drain was open.......????????? until i energized gate.....i dont know why they all seem bad now....they r all new
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #69
                    have to go ..at work.....thanks
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #70
                      thanks budm
                      i am going to try to test pin 2 using the large cap neg as ground
                      to be safe i will electrical tape off all areas around pin 2 so i dont touch anything else and also other areas of board to be safe
                      ill let u know later what i get
                      ill check pin 2 voltage without pwr on applied and then with pwr on applied correct?
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #71
                        like i said shop jimmy sells a 12 pc set of componenets for this power supply on ebay for 27.00............but the issue is i will not continue trying to repair this tv if main board and power supply bad since it wont be worth it .....new tvs are so cheap ...repairing tvs now really isnt as good of an idea as it used to be..........if i can repair it cheap i repair it..if not i toss the tv out ...thats unfortunate but thats just how the electronics industry is nowadays....most everything is considered dispoisable.....wish the good ol days were back ........when fixing things was a good thing
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #72
                          remember when plasma tvs were 3k to 10k and lcd tvs were over 1k???
                          now plasma tvs are 399.99 for a 50 inch 1080p
                          nd lcd tvs under 200.00 for 42 inch 1080p
                          laptops are same way....i sued to like repairing laptop computers but not anymore since a new laptop is only 199.00..............repairing just doesnt make sense
                          its more of a hobby that i like to tinker with here and there....i have no education with electronics just gather info from people like u and has helped me do a lot of basic troubleshotting....its fun
                            I do not do repair works for living, it is good for learning experience which is worth a lot to me to use and apply to my line of work on what not to do when design the products. You cannot beat hands on experience.
                              It's becoming less worth it now for me too. In another year or so, it's not going to be worth fixing anything that isn't a superthin LED TV. And so many of them have bad panels...
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #75
                                tom m thats a very accurate statement...........not even sure why tv repair shops are even around.....they cant be doing very well
                                remember when crt tvs were expensive and was worth spening 100.00 to get it repaired
                                in the old days a 32 inch sony crt would run about 600.00
                                and back in the early 70s and 80s tvs were even more........electronics industry as a whole has become disposable and thats a fact
                                the problem is china..and india..........and out government allowing them to send products here for free............usa cant compete with hourly wages in china and india at about 10 cents an hour.....oh well
                                back to my issue lol
                                ill try testing voltages shortly im at work right now and when i get a min i will do some testing
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #76
                                  fyi even worse is you got these ebayers and other tv parts sellers trying to sell older model lcd and plasma tv parts for more than buying a new tv..........why????
                                  parts for lcd tvs older then 5 yrs should be real cheap but they arent....they are trying to rip people off ...but it actually hurts them in long run....example...why would someone pay 100.00 for a power supply for a old polaroid lcd tv when they can buy a brand new lcd tv for same price..with better features....and new.....i always wonder the strategy they use....its not a good idea......supply and demand doesnt apply here since a new lower cost lcd tv is now an option instead of repairing the old tv....
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    #77
                                    hi budm
                                    i want to try to test pin 2 today....i want to make sure i have it right
                                    u want me touch neg side of large 450v cap with neg probe and pos probe to pin 2?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5095
                                      • New Zealand
                                      #78
                                      Yes, that would make sense - you are measuring on the primary side of the PSU so the ground reference has to be hot ground - which is the negative lead of the main capacitor (and anything it's connected to)
                                      When measuring voltage on the secondary side, you use the chassis, or cold ground.
                                      Getting them mixed up will mean you'd get incorrect voltage measurements.
                                      -David VanHorn
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #79
                                        hi update i bought a new mainboard and still 100% dead...no standby light even though i do have 3.3 standby voltage..........
                                          Post #70
                                          thanks budm
                                          Poat #77
                                          hi budm
                                          Post 79
                                          So we never finish testing the power supply and now you bought the new MAIN board, and I am not about to go back and read the old posts form August again.
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • piposarcade
                                            Samsung UN50KU6300 dead no standby led
                                            by piposarcade
                                            01-04-2024, 01:33 PM
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                            05-22-2024, 02:07 PM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
