Sony HCD BX7700dbi CMT flashing standby
  • rabbituk
    • Apr 2020
    • 7
    I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
    So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode D331 and I see a 13.5VDC across that component. Am I correct in thinking that this indicates a short to ground the other side of D331. With the unit powered off there is no short to ground from D331. With my DMM in diode mode looking at npn transistor Q333 which if failed short would provide a path to ground, I am seeing a voltage drop on that transisotr base-collector of 1.6v and base-emitter of 1.1v. Is that good? Can this be measured in circuit?
    Also I wanted to verify that the power board wasn't causing any problem and I have measured the voltages supplied by the power board with the relay pin grounded but without any load. Is this a good test? The voltages seem to be stable.
    The electrolytic capacitors that I've tested on the board all seem good. There was one that I needed to take out of circuit but otherwise all good including ESR readings. Some of the resistors R425 and R461 are roughly half what they should be but I don't think that is causing the protection mode to kick in.
    Any pointers much appreciated. Service manual is attached. Main board is on page 27-29.
  • rabbituk
    • Apr 2020
    • 7
    A concluding update, I solved this by temporarily soldering in a switch to ground the relay line and thus enabling me to turn on the relay for short periods of time. The unreg line did not have the correct voltage and eventually I managed to track this down to faulty rectification diodes on the power board. I replaced diodes D11-D14 and the stereo is now up and working again.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • H34TO
      ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
      by H34TO
      Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
      06-17-2025, 07:17 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • delpiero3
      Sony Vaio SVS MBX-261 board failure
      by delpiero3
      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
      Nevertheless, let's say, i don't come as a total beginner.
      I have this old laptop, which suit perfectly my needs, with the...
      10-29-2024, 06:16 AM
