Lvds
  • Wox
    • Aug 2014
    • 11
    • Scotland
    Lvds
    Can anyone help? I have a Samsung LE40A686M1F which has a tab fault. The panel/screen is a LTF400HC01. I got a replacement screen which is an LTF400HF01 as I thought it would be compatible. I also had to get another T-con as the HC01 has 4 tabs from panel to tcon but the HF01 only has 2. I am now getting tab fault like symptoms even though the screen had been fully tested. Has anyone had experience of this or have any suggestions?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Lvds
    "Fully tested" ?? says who?
    Are panel and Tcon confirmed to be compatible with your main board?
    • Wox
      • Aug 2014
      • 11
      • Scotland
      Re: Lvds
      The company I got it from salvage parts out of LCD tvs and they had left the tv to soak for 8 hours and no tab faults. The tcon in the HC01 is a FRCM_tcon_v0.1 and the HF01 tcon is 4046fa7m4c6lv0.4 I haven't checked compatability with the main board.
        Re: Lvds
        Fact is, most of the panels you'll buy off eBay are actually bad...
        Also storage can induce moisture into the panel which can lead to a tab failure.
        The picture is blurry, or red tinted on only one side? This can be a bad tab bond.
        • Wox
          • Aug 2014
          • 11
          • Scotland
          Re: Lvds
          I work for the company I got it from. The tv only needed a couple of caps replaced and then worked fine from cold and worked fine for 8 hours so this leads me to believe the screen/panel is good. The tcons are the only difference. There are extra connectors on the 4046fa7m4c6lv0.4 could I need an extra cable from main board to tcon for this configuration?
          • mmartell
            • Oct 2013
            • 3189
            Re: Lvds
            Post pictures of the two tcons.
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help NeededπŸ™
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • jdawg99
              Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
              by jdawg99
              Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
              Any advice welcome. Thanks in advance....
              09-18-2022, 05:30 AM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
