Onn tablet screen
  • cashkennedy
    • Aug 2011
    • 668
    Onn tablet screen
    An ebay seller shipped me this broken tablet by mistake, and so I got my money back, but there are a decent amount of these seemingly in perfect shape but with screen issues (this tablet was clearly a return that had never been used or setup, so I don't think any physical damage occurred, also is a kids model so large bumpers on cover that isn't in picture) Is this a loose lvds cable or anything repairable beyond replacing the screen which would come with its own integrated tcon which is maybe where the problem would be?
    The power on screens just exhibit the sideways smear, once it is on it was lighter image then normal for a while then after a few seconds started getting more Grey and there was nothing left of the image, rotating tablet kinda reversed the degredation by a few seconds and when you restart it it clears up enough to say restarting in center. I'm not an expert but it seems like it lacks the power stability to maintain the image when the image is bright white but on darker screens like when turning on or restarting it is able to display the image somewhat. So perhaps DC-DC related power issue in the board attached to screen. In a tablet like this there's usually just a single ribbon cable which must transmit the power for Backlight and the video signal? So I'm not sure if there really even is a lvds style connection?
    Ultimately just curious if it's anything repairable, if fault is in the screen module. Most likely not worth it to replace the screen even if it was available since these are around $50-70 on ebay
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
  • dicky96
    HP Elitebook Screen blank - backlights but no image
    by dicky96
    Hi guys
    I'm trying to fix this laptop screen
    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
    OK so I have the original screen which works but has lines across the bottom quarter of the screen
    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
    04-28-2021, 07:30 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • speedtime07
    i life zed air cx5 no image on screen
    by speedtime07
    hi everyone ,
    There is an image on the external computer screen ,
    flexi cable test ok - screen test ok -
    What alternative should I look for?
    thank you for your support​
    04-10-2025, 06:24 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
