echostar hds-600
  • bootlegger17
    • Sep 2012
    • 56
    • isle of man
    echostar hds-600
    I have an Echostar HDS-600 freesat box which will not power up.
    I am a little familiar with the basics of electronics, but am worried when it comes to things to do with power input which is what I believe this is.
    Internally the motherboard is clean and visually there are no blown components. The power board and controller board are one unit.
    It uses a figure 8 power connector.
    Internally it has a large fuse rated to 25A 250V, but when I multimeter this, it only shows 17V going across it. I believe because it is a figure of 8 type input, that there is some circuitry that must determine which is the 240v power rail (uk) and switch as appropriate.
    Should/would I be expecting ~240 on this fuse and should it be switched to the + rail by this point? There is very little prior to hitting the fuse from the mains lead.
    There is one cap and one resistor going to ground. There is also an Okaya LE104 rated at 275v sitting at the far point of the fuse and it has a linkage back to ground. What it this Okaya?
    Would be grateful for any input on this. If you need more answers or details, please ask.
    Regards
    Jason
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: echostar hds-600
    pics?
    Follow the white rabbit.
      - The power supply will be designed for the UK only. The box is an original E* design specific for UK market. I think it was designed in the Steeton office. No circuit to determine 240V etc.
      - I doubt you have a 25A fuse in a set top box.
      - You need to test fuse out of circuit.
      - I would focus on testing secondary voltages.
      I work for E* but cannot comment on any specifics as there are confidentiality agreements in place. No publicly available schematics (and don't ask me to get you them, sorry.)
      • bootlegger17
        • Sep 2012
        • 56
        • isle of man
        Yep will get some. however more of an update first.
        I couldnt believe I was only getting 17v on the fuse so I re-evaluted my testing.
        On the Hot side, if I place my multimeter on the ground to the Neutral pin on J1 (power input) and test various points, I see I am getting 240v through the fuse, and power seems to be going through to aother test points on the main board.
        If I ground the multimeter to the chassis instead, then I can only read 17v through the fuse.
        Jason
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Originally posted by tom66
          - The power supply will be designed for the UK only. The box is an original EchoStar design specific for UK market. No circuit to determine 240V etc.
          I work for EchoStar but cannot comment on any specifics as there are confidentiality agreements in place. No publicly available schematics (and don't ask me to get you them, sorry.)
          i have disassembled enough echostar (read "disk network" in the US) so i will take a shot in the dark.
            Yes, I'm pretty sure Echostar makes boxes for Dish but they are designed by the American office, the division I work for is specific to Europe and some other regions. The designs and procedures are different. Until about 8 years ago it was known as Eldon Technology...
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              with testing to frame you are reading through the X filter caps, so seeing 17v is not to surprising. return should be neutral (blue?) from here on.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                i think they are one in the same in the US. there is an echostar building in Denver with a Dish network is hiring sign outside.
                • bootlegger17
                  • Sep 2012
                  • 56
                  • isle of man
                  pics attached as requested
                  Since learnt that the Okaya is a line noise suppressor
                  • bootlegger17
                    • Sep 2012
                    • 56
                    • isle of man
                    My Bad
                    @Tom you are right - its a T1.25A fuse, not 25A - Fuse tests good out of circuit.
                    Shame you cant get the schematics, but i understand 8(
                    Ignore my email when you get back to work then as I already emailed asking that exact question!
                    Can you answer this then? Can you supply refurbed boards?
                    Didnt expect such a flurry of responses so soon
                    Jason
                      I would check for ~320V across the 400V cap, it may be easier to test across bridge rectifier.
                      Then check for low voltages on secondary; there is probably a 5V and a 12V for the hard disk. Both of those will probably be always present.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        QFT! Even in USA! Wouldn't 3,000+ W make the lights dim every time you turn it on? It's not a compressor, for cryin' out loud.
                        I believe 25+ amps would make my T12 fluorescent light dim a lot. It definitely does seem to almost go completely out for a second when my USA-made compressor kicks on!
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • bootlegger17
                          • Sep 2012
                          • 56
                          • isle of man
                          @Tom66
                          If I ground to neutral pin at J12 power input and test to right hand side of R426 I get ~246v. Why do you think ~320?
                          I dont get anything on the +5 or +12 rail from the HD
                          Jason
                            The ground is your negative of your filter cap. You will get 320V peak across the cap in any 240V mains country. The mains peak being given by 1.4 x 240V AC in this case but it applies for 120V AC too (160V DC in that case.) Make sure to have your meter on DC volts.
                            • bootlegger17
                              • Sep 2012
                              • 56
                              • isle of man
                              OK I admit I am lost!
                              If I ground on the negative of the 400v cap (CR52 lead end by cap is the closest point I can get to) and test positive on the R426 (closest point I can get to) it returns ~700+ (my multimeter is only rated to 600!)
                              I assume you meant test the HD rails as DC - I did, but still nothing.
                              Please have patience with this n00b!
                              Regards
                              Jason
                                The positive should be touching the positive of the 400V cap not of any resistor.
                                • bootlegger17
                                  • Sep 2012
                                  • 56
                                  • isle of man
                                  @Tom66
                                  So are you saying that if I test points 3+4 I will get different reading than what I would testing points 1 and 2 on the attached screen shot? Only difference being I am testing the top side points of 1 and 2.
                                  I would have thought they would return the same results being on the same part of the track?
                                  Maybe once again I have learnt something new again....
                                  I will test tomorrow sometime. getting late for me now.
                                  Thanks for your input so far.
                                  Regards
                                  Jason
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    I'm going to go out on a limb with my rudimentary electronics knowledge and say you're ok to measure there. When is the last time you changed the battery in your DIMM ?
                                    • bootlegger17
                                      • Sep 2012
                                      • 56
                                      • isle of man
                                      Hi Again.
                                      OK so I tested again on the reverse side on the cap points, and found the following;
                                      Multimeter set to DC, C486 returned results 322-323v
                                      Also checked the reading from the topside two point I mentioned previously, and it returned the same results. Difference was I was testing in AC not DC.
                                      Also on hot side, cap C484 fluctuates from 11.5V down to 8.8V and then cycles.
                                      on cold side, some more test point results
                                      CR57 is returning a fluctuating value - resting as 12v but ramping to ~150v and dropping down to ~50-75v, then resting at 12v again. what does this imply?
                                      C494 and C499 are at 11.94V
                                      C495 Could get no reading from
                                      Regards
                                      Jason
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Aha! You're on to something there. Unplug the device, pull the board out and replace C484 with one of same uF and volts and see if it powers up.
                                        If it does not, and still fluctuates, you've got a short on the secondary side. But i'm fairly sure that cap alone will fix the problem.
                                        A working TV? How boring!
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • Acnologia
                                          Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                          by Acnologia
                                          Here is a pretty crazy one.
                                          Step 1.
                                          Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                          Step 2.
                                          Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                          Step 3.
                                          Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                          Step 4.
                                          Lets ,dive into the board. I see the edp cable on the...
                                          05-07-2025, 07:16 AM
