Milk in TV - strange colors
  • Behemot
    • 4845
    • CZ
    I obtained this TV with the info that the owner's little daughter has been supposedly painting the TV with milk It's an LG 32LW570S.
    I have been reported there was something with the ribbon cables but I have not found any residue or problem at any conenctor or cable, they are all clean, maybe cleaned by the owner, not sure. I can clean them with alcohol but don't think this is the right path. Anyway, the TV shows this
    instead of
    It seems to me as usuall voltage-buffer problem? This is the Tcon (not my image)
    There seem to be two chips, both SMD so the milk could have been sucked between the solder balls as the tiny space there behaves like capilary. They are TPS65194 and BUF08630.
    voltage readings at pins:
    GMA1: 16,67
    GMA3: 14,72
    GMA4: 13,90
    GMA5: 12,74
    GMA7: 10,68
    GMA9: 8,58
    GMA10: 0,50
    GMA12: 6,13
    GMA14: 4,03
    GMA15: 2,92
    GMA16: 2,17
    GMA18: 0,34
    H_CONV: 0,01
    POL: 1,66
    I would say channel 10 is the problematic one?
    Re: Milk in TV - strange colors
    "GMA10: 0,50"
    "I would say channel 10 is the problematic one?"
    Yes.
    • Behemot
      • 4845
      • CZ
      And the bad chip would be the TPS65194 one, right? I am just afraid if it could not be any problem in the ribbon board (there is PCB where the ribbons are soldered/glued), in the way it would be shorting this channel. In the case of AS15F it always helped on the other hand there was no milk
      • R_J
        • 9514
        Did you check the bottom of the screen for residue? If the t-con is at the bottom on this tv the milk may be on the circuit board that connects the panel to the t-con.
        • Behemot
          • 4845
          • CZ
          Yeah I have checked that right away, found nothing from the signal board through Tcon to that panel board. I'll ask the owner today if he has actualy cleaned anything inside…
          • Behemot
            • 4845
            • CZ
            This is the part where the milk was
            SMD components seem fine. The dark spots on the golden joints were probably burned or oxidized or something. The paths were opened, I have tried to connect them like this but there was no change. They do not seem to be connected anywhere beyond the SMD joints (= dead end) so probably does not matter if they are opened.
            One thing though, if I disconnect the ribbons, some voltages dissapear from the test pads. Seem to me some signals go through one ribbon to one display PCB, than through the LCD to second PCB and back to the other ribbon. So there still may be some problem in between, but well, everything seems fine, if the display itself is bad internally, I won't know before the gamma chip is replaced anyway so I will just go for it.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              instead of
              GMA1: 16,67
              GMA3: 14,72
              GMA4: 13,90
              GMA5: 12,74
              GMA7: 10,68
              GMA9: 8,58
              GMA10: 0,50
              GMA12: 6,13
              GMA14: 4,03
              GMA15: 2,92
              GMA16: 2,17
              GMA18: 0,34
              H_CONV: 0,01
              POL: 1,66
              id leave it as it is,that picture looks amazing!!
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • Behemot
                • 4845
                • CZ
                orly Well the customers thinks otherwise…
                • Dang
                  • Aug 2013
                  • 440
                  You know what worries me, the first 6 to 7 contacts of the ribbon cable on the left, they look to be tarnished, get some contact cleaner and spray a little in that area and then press on it while the Tv is on, see if it makes a difference.
                  • Behemot
                    • 4845
                    • CZ
                    I've tried pressing the contacts as very first thing, even before I noticed this area. Tried all of the flexes, there was no change at all no matter what I did with them…
                    I have checked once again just to be sure, that was probably just something on the top of the ribbon, not under that - as I have been cleaning it, I can see nothing out of the ordinary now.
                    What do those long chips (silicon wafers without any cover) soldered directly on those LCD ribbon cables do? All of them are pretty hot.
                    • Behemot
                      • 4845
                      • CZ
                      Still not sure whether to get TPS65194, BUF08630 or both. The latter is 8+1channel gamma voltage generator, the former is 13channel level shifter. I guess either one can be bad?
                        They are the source drivers. 10 bit DAC 0-15V output, approx 5,000 total channels (around 1,000~2,500 per IC typical.) They are responsible for image data on the panel.
                        • Behemot
                          • 4845
                          • CZ
                          So which IC should I get? Both?
                          • Behemot
                            • 4845
                            • CZ
                            Up?
                              I don't have any idea which to get, maybe the only option is to replace T-con board.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have worked on a LG which had missing voltages, in two or three places and by replacing the IC on the T-con and one more time getting another T-Con board, did not fix the problem(did not have picture at all). Then I have checked the LCD panel itself, and I have found partially lifted ribbon, on the panel PCB.
                                I think, that those first 6-7 tracks from the ribbon cable, are actually lifted.
                                Somewhere I have read, that with some kind of T tip solder iron, which has some Teflon coating or similar material, can be heated up and it should glue back to the PCB.
                                Anybody knows anything about this procedure?
                                • Behemot
                                  • 4845
                                  • CZ
                                  But than pressing it would help, no?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Unfortunatelly even after swapping both ICs problem persists.
                                      MSI Prestige P65 9SG-1274 Creator Notebook P Specification for Upgrade or Repair
                                      This specification for the MSI Prestige P65 9SG-1274 Creator Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 9SG-1274 Creator boardview and P65 9SG-1274 Creator schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 06:50 PM
                                      MSI Gaming GS65 Stealth-1667 Notebook GS Specification for Upgrade or Repair
                                      This specification for the MSI Gaming GS65 Stealth-1667 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS65 Stealth-1667 boardview and GS65 Stealth-1667 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:00 PM
                                    • spleenharvester
                                      Reverse engineering of 18650 4-channel tester
                                      by spleenharvester
                                      Hi friends
                                      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                      05-04-2025, 02:43 AM
                                    • dicky96
                                      American Audio VLP1500 Distorting on one channel
                                      by dicky96
                                      Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                      Protection and Clip LED are off
                                      There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                      I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                      The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                      07-13-2022, 05:25 AM
                                    • dicky96
                                      Hitachi V19B01922 Channel Tune problem
                                      by dicky96
                                      Hi Guys
                                      I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                      He also has an LG TV, so three screens in the bar
                                      I installed three Satlink ST-6503 DVB-T Modulators
                                      This model https://www.aliexpress.com/item/32916553905.html
                                      These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                      02-09-2023, 09:20 AM
