Hinasie 50K360G
  • Tech 57
    • Aug 2014
    • 37
    Hinasie 50K360G
    I have a Hinasie No picture Just backlight
    T-con has 12v disconnect the right side ribbon cable that goes from the T-con into the panel
    Half Picture with video with connected blanks video.it seems like a short.
    Don't know if T-con is bad or the panel itself.
  • sordids999
    • May 2013
    • 2161
    Re: Hinasie 50K360G
    please post good clear pictures of the whole chassis, and then pictures of each board
    • 70JUDGE
      • Jul 2010
      • 81
      Re: Hinasie 50K360G
      Have you tried both T-Con cables one at a time?What I ended up doing was taking a piece of tape,and covering a few of the contacts on the ribbon cable,and plugging the cable back in.The whole picture was perfect,except for a vertical line on the far left,and a horizontal line along the very bottom.Mine had a crack in the screen on the lower left corner,so the lines could have been because of the crack.
      I hope this helps.Please let me know.Thank You very much!
      Tyler
      • ecking767
        • Oct 2009
        • 492
        Re: Hinasie 50K360G
        I have seen this same model Hisense 50K360G with a blank screen with the backlight on for sale. I very curious about this model. this could be a bad T-CON board.
        • ecking767
          • Oct 2009
          • 492
          Re: Hinasie 50K360G
          I pick up a 50 Hisense 50K360G with a blank screen, the owner claim the screen just when blank while watching it. I remove the back cover, and doing a visual inspection of all board found nothing.
          Power up the TV and confirm the problem, back light turn on and the screen was blank. I was able to get sound using the HDMI port.
          Checking the T-CON board, the fuse wasn't blown and +12 volts was present. This T-con board have electronics components on both, very rare to me. Checking voltages on the T-CON regulators all was good.
          So I remove the framing around the LCD screen, this is what I found. see picture. This is one of the flat ribbon cable going to the LCD screen. I'm going to attempt to fix this using very thin wire wish me luck !!
          • ecking767
            • Oct 2009
            • 492
            Re: Hinasie 50K360G
            after further review, this can't be repaired, so I'm gotta scrap this unit and sale the parts online.
            • ecking767
              • Oct 2009
              • 492
              Re: Hinasie 50K360G
              Here is a better picture of the damage ribbon
              • freakaftr8
                • Oct 2012
                • 3743
                Re: Hinasie 50K360G
                Hense this is the reason why I like plasmas better lol. I just picked up one of these for free last night same exact problem same symptom same burn in the ribbon cable. Absolute garbage but I'm surprised if panel was made by AUO! it appears that there's some kind of rubbing action going on where the ribbon cable meets the metal frame and it rubs through a section of the cable.
                • Fly_Among_Stars
                  VIZIO E70-E3 Half picture with half TCON
                  by Fly_Among_Stars
                  I have a VIZIO E70-E3.
                  Symptoms: Black screen, no picture, but LED backlights are working.
                  I probed the power board and voltages are as listed on the board.
                  Main board appears fine, too.
                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                  There are two separate ribbon cables feeding the LCD.
                  If both are connected, the screen is black.
                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                  04-24-2023, 08:20 PM
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • shelby5041
                  Samsung LCD TV no picture backlight on no 12v at tcon
                  by shelby5041
                  hi
                  i have a samsung lcd tv
                  it powers on with sound and backlight but no picture
                  all voltages from PS are good 12v 3.3v and 5v
                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                  no 12v at the tcon fuse
                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                  the odds of having 2...
                  10-08-2021, 08:21 AM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
