how do i short 24c02wp eeprom chip
  • mcross
    • Sep 2011
    • 201
    need to short 24c02wp eeprom chip in rca tv. stuck in firmware update screen. comes on by itself when plug in
    mike
  • Dang
    • Aug 2013
    • 440
    Re: how do i short 24c02wp eeprom chip
    I have no idea if this is of use to you but seems interesting: http://www.engineersgarage.com/micro..._reset-circuit
    • munirutech
      • Oct 2013
      • 72
      • Ghana
      i think is pin 5 is 8
      • Dang
        • Aug 2013
        • 440
        Data sheet for you: https://cdn.badcaps-static.com/pdfs/...823e53cf34.pdf.
          • 31294
          search "ponyprog"
            Shorting an EEPROM is unlikely to resolve a firmware problem and could create further problems.
            • Dang
              • Aug 2013
              • 440
              There is a memory reset but it seems specialist gear is needed, it's described in the PDF.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Here is my input-Hope it helps.
                1. Determine the pin configuration for your particular EEPROM. Let's say Pin 5 is the SDA and Pin 8 is the VCC.
                2. JoinPin 5-SDA and Pin 8-VCC with a jumper wire.
                3. Power ON the TV and hold for 20 seconds. (Observe if a warning message appears on the TV screen.)
                4. Disconnect the Pin 5-SDA connection.
                5. Shut down TV.
                6. Disconnect next end of the jumper from Pin 8-VCC.
                7. Power On TV.
                  Jumpering an I2C bus to Vcc is a bad idea - it is an open collector bus so potentially you are shorting the supply rail. If anything jumper to GND/Vss
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Well I think it is pins 5 and 6 though no guarantee - at your own risk.
                    https://www.badcaps.net/forum/showthread.php?t=18199
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Yes, indeed....Instead of jumping SDL pin to VCC pin you can jump SDL pin to GND pin and get the same result........and of course....no guarantee-at your own risk.
                      From my previous post #8 in Step 4 when the SDL conn ection is removed with the TV ON what will happen is the EEPROM will be updated with null values that TV could boot with.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        Looking at the PDF posted for the 24C02/24C04 EEPROM Pin 8-VCC, Pin 4-GND and Pin 5-SDA
                        • mcross
                          • Sep 2011
                          • 201
                          thanks guys, will post results
                          mike
                          • mcross
                            • Sep 2011
                            • 201
                            I tried these steps and no change. now I did not tell all. I can use the remote and buttons to move between update and current software info, but can exit the menu. tv comes on when plug in by its self
                            mike
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              so what does it do when you goto current software
                              • mcross
                                • Sep 2011
                                • 201
                                just gives the info.no other options
                                Mike
                                • mcross
                                  • Sep 2011
                                  • 201
                                  have now tried all suggestion as above. does nothing different
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    And when you press update software?
                                    Before you try that does it update from Usb socket and if so have you got the latest software?
                                    By the way the timing for shorting 5 and 6 is a bit tricky some people have tried it a number of times before a success.
                                    • mcross
                                      • Sep 2011
                                      • 201
                                      yes it does. firmware is no longer available to down load, first thing I did look for.,
                                      will try 5-6 again
                                      Mike
                                      • mcross
                                        • Sep 2011
                                        • 201
                                        sorry , when press update software it looks for it, says none found
                                        Mike
