Hisense H55U7B vertical stripes
This topic has been answered.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4451
    • Italy - Milan
    Ok to be more precise, needs to replace completely the old solder, If my suspect Is right...
    pS:
    to have a confirmation, the half test image gets Better with the passing seconds?
    My suspect Is now different, i think you have problems with the cof Tab where the half connected side displays only bars and no image, leave alone for now the task of resoldering, try this other task, keep a freezing air can or compressed air upside down or butane gas, freeze a lot the cof Tab more towards side and with all connected test normally the TV..
    • Diah
      • Feb 2013
      • 6435
      scarp it
      • lotas
        • Jan 2016
        • 4744
        • Russia
        And what will happen when using butane gas when freezing the chip and turning on the TV, a small spark and there is no owner of the TV and apartment!
          • 12268
          • U.S.
          +100, Thats just about what would happen too.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4451
            • Italy - Milan
            I don't know what you are complaint of Lotas, butane is very volatile, he will turn on the set surely after no more gas is around.. it takes few seconds.. we begin again with these sterile polemics, with the "known party pooper" around like vultures..
            PS: The vulture here criminalized a website change and telling he disapper from here and 5 min. he are here again crushing the olives to me and the staff.. in italy it is called "uomo di m*rda senza orgoglio"... how can this happen?!
              • 12268
              • U.S.
              #26
              So this monkey has his nose out of joint again...just because I agree with someone that his "testing" suggestions are hazardous. He IS INDEED just a joke.
                • 12268
                • U.S.
                #27
                complain complain complain yada yada ...So how do I get davi back on the IGNORE list??
                from admin - go to your profile and then edit your settings. under accounts you can add to ignore list
                  • 115472
                  #28
                  Just to address the experts on this post complaining about the new layout. previous vbulletin had major security issues so there was no choice to upgrade. I have made alternate (including dark mode) available in the footer and will release more soon.
                  As for being ad revenue orientated. this site makes a significant loss each month which is only partly subsidized by ads.
                  • halen
                    • Jun 2011
                    • 16
                    #29
                    Hi again, I did all test, try to freeze bad side drivers, all drivers r+l and finally all together with tcon and no change. Still same stripes. When I connect only 12V to the tcon, then good side switch ok, bad is switching slowly and took some time to get to final color. I have microscope and checked joints on tcon bga and it's seems ok.
                      • 12268
                      • U.S.
                      #30
                      I wouldn't worry about freezing it, it's not really a reliable test anyway.
                        • 12268
                        • U.S.
                        #31
                        Also not the first time I have heard this COMPLAINT, I hope your other business ventures are profitable so you can write all this off.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4451
                          • Italy - Milan
                          #32
                          when the self test is running slowly, does the tcon main chip over heats? No other reasons to getting slow, but the panel is the overload that makes it working bad, maybe a bad discrete on the panel strip board..
                          • halen
                            • Jun 2011
                            • 16
                            #33
                            No, it's getting slow immediately after powering on. Good side switching normally and bad side is slow to get final color. I mean when it's connected together left+right. And of course when I connect only bad side it's slow too. It doesn't matter.
                            It's not overheating, temperature seems normal. I checked everything on driver board, no shorts or bad values.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4451
                              • Italy - Milan
                              #34
                              remove carefully with hot air the diode packs on the bad side, it's difficult to represent in mind exactly how is the issue but i think i have it in mind now.. if you watch carefully the top or bottom side you see probably a marking line where over that image is better... (?)
                              when the test colours are blurred, its the time where diodes leaks a current and losts syncs on clocks.. you can also try to freeze those diodes..
                              • halen
                                • Jun 2011
                                • 16
                                #35
                                Thanks a lot. Removing protection diodes make the job. Picture is back. So one of them were bad. I will replace them.
                                Thank a lot Jan
                                • lotas
                                  • Jan 2016
                                  • 4744
                                  • Russia
                                  #36
                                  Thank a lot Jan
                                  I wrote about this in post 11.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4451
                                    • Italy - Milan
                                    #37
                                    Now the curiosity corner, for me.. does the metal shield for the strip boards touch well with strong electrical connection with the screen back chassis? It's important that it does it for the esd..
                                    • halen
                                      • Jun 2011
                                      • 16
                                      #38
                                      Driver board earth is connected by conductive tape to the chassis. And I measured it and it's ok.
                                      I know about post 11, but I measured by meter if there is some bad resistance and nothing bad at this test.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4451
                                        • Italy - Milan
                                        #39
                                        No i talked about the metal frame that covers the boards, it's important for the esd
                                        • halen
                                          • Jun 2011
                                          • 16
                                          #40
                                          Yes, it's attached to the main frame with 6-7 bolts. Another question where to get SP1064E-04UTG Tvs diode component. Or some alternative on AliExpress. Because I found one in Mouser, cost low, but shipping of parcel costs a lot.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • kotel studios
                                            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                            by kotel studios
                                            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                            08-06-2025, 02:07 AM
                                          • ahoonid
                                            MacBook A1990 vertical stripes on external screen
                                            by ahoonid
                                            Hey everyone,
                                            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                            The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                            06-20-2025, 08:54 AM
                                          • jason123
                                            Hisense 65R6E3 double-image / horizontal strips - TCON?
                                            by jason123
                                            Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                            07-19-2025, 08:07 AM
                                          • kevinman
                                            KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
                                            by kevinman
                                            Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
                                            12-17-2023, 06:22 AM
