Goodmans LCD tv model LD3261hdfvt - white screen and sound
  • janine
    Technical Woman
    • Jul 2014
    • 6
    Hi
    I have a goodmans LD3261HDFVT 32" LCD tv and I have a problem with it. When I first acquired it it would come on for a few seconds and show a channel number before going back to standby. After much searching I found and replaced the PSU board which stopped the standby issues.
    The tv then came on and gave me sound but no image on screen other then what can only be described as a bluey-white screen.
    Therefore I changed out the mainboard and the T-con board and still no joy in getting a picture.
    What could be causing this? Could it be the screen is at fault? Im stumped for ideas.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Goodmans LCD tv model LD3261hdfvt - white screen and sound
    Only seems to leave the panel but if it had something on{numbers} then
    it probably isnt.
    Have you tried it again with the old main board.
    Are you aware that the Main board has to be matched to the panel.
    Frequently so has the Tcon.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Do you need more help to see if the boards you have are a good sub or help to troubleshoot the old boards?
      • janine
        Technical Woman
        • Jul 2014
        • 6
        It was a bad main board that caused these issues. replaced and TV is working brilliantly
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Thanks for reporting back- pleased to hear its fixed
          • nomoresonys
            • 12074
            • U.S.
            so the first mainboard you bought was bad then?
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • EazyBone
              Sharp LC-65Q620U White Screen
              by EazyBone
              Another TV topic!!
              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
              08-21-2024, 12:56 PM
            • nickgronk
              iMac PowerPC G4 very low sound • Sunflower Model
              by nickgronk
              Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
              I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
              I cannot find any schematics...
              08-05-2024, 07:04 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • hcinne
              Dell G15 ryzen edition black screen 2 amber 1 white
              by hcinne
              I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
              07-23-2024, 07:56 AM
