sony kd-49xf9005 4 red blinking problem
This topic has been answered.
  • YasaCh
    • Apr 2025
    • 14
    • Morocco
    Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks
  • Answer selected by YasaCh at 05-07-2025, 10:40 AM.
    tiki66
    • Jul 2016
    • 63
    • Croatia
    Here you go:
    https://ibb.co/5g4rhk2V
    (pin #27 on LD board - connector that goes to MB)
    • Diah
      • Feb 2013
      • 6598
      I2C communication
      • YasaCh
        • Apr 2025
        • 14
        • Morocco
        Originally posted by Diah
        I2C communication
        thanks for reply but i know its a backlight error
        i only need to know where to find a (BACKLIGHT ERR) PIN in the board connector to solder it to the ground for bypass the protection of the backlight failure
        • bohaboha
          • Nov 2012
          • 1035
          • sweden
          if you add some clear pictures it will be easier to help you
          • tiki66
            • Jul 2016
            • 63
            • Croatia
            Here you go:
              • 12331
              • U.S.
              If you can just post the pictures here, it will allow for folks to better help you. Many don't want to deal with wandering around the www just to see pictures.
              • YasaCh
                • Apr 2025
                • 14
                • Morocco
                sorry brothers for the my late response..i know my post is missing pictures that is bcs i'm not in the place where i have the tv...
                anyway thank you tiki66 for your response,it works for me and tv works greatly either​
                  • 12331
                  • U.S.
                  My bad, wasn't paying attention, mistook one of the posts. Kill post #6.
                  • YasaCh
                    • Apr 2025
                    • 14
                    • Morocco
                    • YasaCh
                      Sony kdl 40p5500 red light keeps blinking 3 times
                      by YasaCh
                      Hello...
                      my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                      i opened the back cover no sign of damage on the powery suply or motherboard
                      when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                      another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                      07-07-2025, 11:53 AM
                    • Chrissygizmo
                      Sony KD-55XG9505 lines on screen problem
                      by Chrissygizmo
                      Hello again everyone,
                      This is my latest mission, to try getting this Sony tv back to normal working order…
                      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                      02-19-2025, 11:31 AM
                    • shahnld
                      Sony kdl 65xg9505 green amber blinking
                      by shahnld
                      Good Day.
                      I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                      i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                      green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                      01-03-2024, 03:05 PM
                    • Ihandyrepair
                      4 red flash led 65X950G boot Sony and android logo but then black
                      by Ihandyrepair
                      HI guys
                      I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                      here is the issue
                      I have Sony and android logo. but then 4 led red flash lights front of the tv
                      I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                      but then I get black screen and 4 red flash light at the front LED
                      but I get 3 led flash on the LED driver board.
                      I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                      so I tried...
                      07-11-2024, 01:45 AM
                    • crackedprint
                      Sony HCD-HX80R Amplifier Volume Control Problem
                      by crackedprint
                      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                      I have tried a Cold Reset as per the service manual.
                      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                      I have looked all the way through the service manual and tried many online...
                      01-21-2025, 12:18 PM
