Re: Philips 42PFP5532D - Dead
Bridge may not be dead ehheheh may use those caps yet.
I have to ask you did have it plugged in and powered on?
Need to trace back the two middle pins to the mains input
Shouldnt be too much in the way some coils perhaps L????
I have to go out now but back later
Too complicated for me - I dont like it when you cant see what is on the board
for heatsinks. (not that it would help much if I could see)
Its got to be a bit odd that there is NO voltage on the caps when you have some low voltages - must be a dual supply but cant see the other rectifier.
So caps have no voltage because:
1 The bridge rectifier is out? can you see if that is it at D6003 left side
halfway down. - If it is can you test the voltage on the the outer pins
(meter on vDC600) Inside pins should be AC 230v.
2 The traces the caps are soldered to were not cleaned down to shiny metal.
If this gets fixed I would resolder that other big cap
I am pretty sure they are soldered on well, I have done a continuity test as the pic illustrates, all seem to be connected.
Thanks Hamie, so there are supposed to be pads underneath board?
Cheers allLast edited by unit22; 07-25-2014, 04:38 AM.Leave a comment:
C5053 looks like the pad has been lifted.Leave a comment:
If this gets fixed I would resolder that other big capLeave a comment:
Thanks selldoor, heres the bottom of the board.
I forgot to say that the previous owner also replaced:
25v 2200uF Cap (C8023) right mid on board - I have resoldered this one as solder was bad.
250v 820uF Cap (C8061) right top on board - Not resoldered as it looked ok.
Thank youLeave a comment:
Hmm Odd one that - can we have a good clear picture of the bottom of the boardLeave a comment:
volts ohms amps???? If volts and the board is switched on no point in tetsing any other caps yetLeave a comment:
Hi, Thanks for the help, I've just soldered on the 450v 220uF Caps, I tested them with the DMM and I'm getting 0.00 on both of them.
I will test all caps later and post some readings here. ThanksLeave a comment:
If you have looked at other posts and on the net some sets have problems with a pic
that as far as i can tell has not been bottomed- just so you dont put a lot of money into it
and end up with that.Leave a comment:
Thanks selldoor, appreciate the help!
Ok, I'll solder them back on tomorrow, I have some heatshrink so I'll use that.
No problem with testing, I got crocodile clips on the DMM so its a safer than going in with the probes.
I'll post the results soon! Thanks Again for the help :-)Leave a comment:
Solder them back in - use heatshrink or insulation pulled off a mains power cable instead of tape - leave a small gap at the top of each leg and test them.
Meter on 600vdc - you would need to be careful not to touch the heatsink or anything else in that area - If you can get to the bottom of the board test them
there on the solder joints - probably safer option..
EDit - Id guess they are working as you have some voltages on the secondary side.Last edited by selldoor; 07-20-2014, 03:42 PM.Leave a comment:
Thanks both for the help
Hamie, yes they were above the heatsink, as selldoor mentioned they are too big, so they improvised on the previous repair. I will take board off tomorrow and inspect the pads.
Thanks selldoor, how do I know if they are working though?
And thanks for the confirmation of the caps! :-)Leave a comment:
Hi Well they dont look good but having said that they would not stop it working if they were firmly soldered in. In fact you might consider just refitting them until you have the rest working as they will be expensive to buy.
Just in case you are wondering whilst the wrong physical size they are the correct
rating 450v 220uf - see picLeave a comment:
lol wtf? are they sitting on top of the heatsink!?
Are the pads damaged? Take a photo of the underside of the board.Leave a comment:
Hi
Some news... Looks like someone has had a go at fixing it before me, I just pulled one of the capacitors off by hand as it wasn't soldered very well.
I was a bit suspicous about these 2 caps as they didn't look right sticking up like thatAnd the insulation tape
So I need to replace these caps, these EPCOS are 220uF 450V, does anyone know if these are the correct ones to replace with?
Thanks Hamie,
with the X and Y unplugged...
vs...3.54
va... 0.51Leave a comment:
With the x and y sus unplugged what are the vs and va voltages?Leave a comment:
Hi all, wondering if anyone can help me out, I've just salvaged this TV and trying to get it working again.
I have blue light on front, but no video at all.
The green LED on PSU is not blinking, so no fault codes.
These are my PSU readings:
VG...-0.01
VS...1.58
12Val...0.00
VSND_NEG...0.23
gnd_snd...0.00
vsnd_pos...2.26
POWER_OK...0.12
standby... 0.06
12vssb...12.61
dc_prot...0.00
5vsw...5.34
gnd_ssp...0.00
8v6...0.08
5vstb...5.29
relay_sig...0.00
VS-ON... 0.00
d5v...0.26
Va...0.50
I have no idea what these voltages should be.... I have also tested all the removable fuses, inlcluding the small F2001 fuse... Any help please?Tags: None
by kew1701Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
by RubenlilyHey,
I gave up on my last TV and got a new one to try.
Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
Is this fixable in any way or should I just give up on this one too?... -
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by vikivngHi guys pls can someone help with this set..
Tv doesnt not power on.
No standby light.
There is a burn mark by the leg of D501 diode.
The diode tests short in both directions.
I have been reading this usually means the diode is faulty? As normally would be open.
I have not yet taken voltages since this is obviously short I would like to replace it.
Can someone help me with a substitute for this diode since it seems not to be the standard type?... - Loading...
