What causes these vertical lines? LNT4066FX/XAA
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I picked up this Samsung LNT4066FX/XAA over the weekend and when plugged in it displays colored vertical lines all over the screen. Sound is OK. Would this be a T-CON board typically? I would assume so since we have sound and backlight are ok..any suggestions are much appreciated.
    Thanks!
    Joe
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: What causes these vertical lines? LNT4066FX/XAA
    Have you opened up the set yet? On these models typically bad caps on the psu would cause this problem.
    • Shinju
      • Mar 2014
      • 1239
      Also could be bad panel too, I have a Samsung sitting that has this affliction with a good working PS and T-con.
        Bad cap:
        http://s807.photobucket.com/user/bud...?sort=3&page=1
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • Firentiosi
          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
          by Firentiosi
          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
          The issues are as follows: the...
          11-27-2024, 12:33 AM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
