Memorex T3321
  • Mark562
    • Jun 2014
    • 13
    • usa
    Memorex T3321
    I replaced two caps, 10uf 450v worked for a week, then heard a pop opened it cars were fine. I ordered new psu popped it in. The screen will not stay on have audio. It flashes on only for less the a second. What should I check next.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5036
    • New Zealand
    Re: Memorex T3321
    Photos please, would be great. Including photos of the old and new PSUs.
    Where are the capacitors located that you replaced? (Do you know what their function in circuit is?) What were the original capacitors? What did you use for replacements?
    Something going pop was probably something blowing. Maybe a fuse, maybe a component. Inspect the boards carefully for burnt components under good daylight.
    -David VanHorn
    • Mark562
      • Jun 2014
      • 13
      • usa
      Re: Memorex T3321
      Ok The Board is <img src="https://07c64c6ea680b4fd723b32b6563c24fa3e5fef68.googledrive.com/host/0By-2rqlHK3Ked3FsYkQyNTA5ZWs/2014624192321.jpg" style="max-width:100%" alt="Powerboard" />. I think it was part of the board that popped , i have a new one
      • Agent24
        I see dead caps
        • Oct 2007
        • 5036
        • New Zealand
        Re: Memorex T3321
        Link doesn't work, please upload your photos to the forum, that way others can use them for future reference too - external links have a habit of eventually disappearing
        -David VanHorn
        • Mark562
          • Jun 2014
          • 13
          • usa
          Re: Memorex T3321
          ok Sorry, here you go
          • Mark562
            • Jun 2014
            • 13
            • usa
            Re: Memorex T3321
            i left out i havea new psu now
            • Agent24
              I see dead caps
              • Oct 2007
              • 5036
              • New Zealand
              Re: Memorex T3321
              It looks like there has been arc-over between two tracks in that area. Did you clean it?
              Can we get a photo of the other side of the PSU too, to see what is going on there?
              Was the new PSU brand new or used? Can you post photos of it also? Preferably the inside of the whole set also.
              With sound but no picture could be a backlight issue. Do you get sound even with the screen off, or does everything eventually stop? If you shine a bright light on the screen, can you make anything out? (works better at night) It could be the lights\inverter is bad but everything else is working.
              -David VanHorn
              • Mark562
                • Jun 2014
                • 13
                • usa
                Re: Memorex T3321
                Yea,i Cleaned It. Before IGot the New One. The New Is Used I Got It From Ebay. What Would Keep The Lamps Off .
                the first two are the new one
                  Re: Memorex T3321
                  Check the DC voltage on BK_ON (bancklights ON) pin of the CON4.
                  • Mark562
                    • Jun 2014
                    • 13
                    • usa
                    Re: Memorex T3321
                    what should it be the voltage
                      Re: Memorex T3321
                      I need see the voltage when the TV is OFF and when the TV is on, it should toggle.
                      • Mark562
                        • Jun 2014
                        • 13
                        • usa
                        Re: Memorex T3321
                        ok im going to check now
                        • Mark562
                          • Jun 2014
                          • 13
                          • usa
                          Re: Memorex T3321
                          ok just tested from the con4 when off there is zero volts when i power up its 4.8 volts
                            Re: Memorex T3321
                            OK, so it is getting the backlights ON signal OK. So the two 10uf 450V caps on the new board look OK.
                            • Mark562
                              • Jun 2014
                              • 13
                              • usa
                              Re: Memorex T3321
                              well the backlights just flash really quick, yea there looking fine
                              • Mark562
                                • Jun 2014
                                • 13
                                • usa
                                Re: Memorex T3321
                                how do you test the d10 diode, and what part might that play in the invert
                                  Re: Memorex T3321
                                  I believe the D10 has to do with the standby power supply.
                                  • Mark562
                                    • Jun 2014
                                    • 13
                                    • usa
                                    Re: Memorex T3321
                                    ok if this helps before the first board went bad, it worked fine i had changed caps, they were cheap ones , then it worked for three day and now in this spot stuck not sure where to go fromhere.
                                    What circuit keeps the lamps on , why would the lights just flash on but not stay on
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5036
                                      • New Zealand
                                      Re: Memorex T3321
                                      Probably a fault in the inverter circuit, or it could have a bad lamp(s). Maybe it doesn't like your new capacitors.
                                      -David VanHorn
                                      • Mark562
                                        • Jun 2014
                                        • 13
                                        • usa
                                        Re: Memorex T3321
                                        Any idea how to check inverter circuit
                                        • AdrenalinTL
                                          Macbook Pro A1707 - Dead - Battery 'popped'
                                          by AdrenalinTL
                                          Hi Peeps.
                                          Just a quick question please as I am by no means an Apple fundi at all.
                                          Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                                          Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                                          Don't want to go buy a battery for no reason.
                                          Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                                          07-18-2024, 09:52 AM
                                        • EazyBone
                                          Onn 100012588 backlight issue *Solved 70 inch
                                          by EazyBone
                                          Had another one of these 70 inchers from onn and was same problem as others. The picture shows but no backlight. The backlights test fine. The issue is the 450v 10uf capacitor by the backlight connector. Usually the cap bulges, the cap I replaced today for fix was NOT bulging. Replaced anyway and fixed.
                                          Hope this helps someone....
                                          11-19-2023, 06:20 PM
                                        • MicroSMD Lab
                                          MSI MS-16W1 no power, EC replaced by other.
                                          by MicroSMD Lab
                                          Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
                                          03-27-2025, 07:35 AM
                                        • thesame
                                          Asus FX505DD REV 2.0 no power after someone replaced the cmos battery with a screwdriver.
                                          by thesame
                                          I have a dead FX505D, motherboard FX505DD REV 2.0 , the owner replaced the cmos using a screwdriver and he touched something on the board, since then the laptop its not starting, i have managed to see that U8800 (BQ24780SRUYR) charging IC is getting hot under a thermal camera , i have desoldered it but the laptop still doesn't power on, i also have no voltage at power connector on the board. I also replaced the U8800 but still no power. What should i check next?
                                          04-22-2024, 01:21 AM
                                        • zlr8r
                                          HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                                          by zlr8r
                                          Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                                          To begin with, this laptop was dead-dead.
                                          Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                                          • am getting white power led
                                          • 5-long-flashes on CAPS Lock and NUM lock
                                          • then, fan full speed
                                          • CPU heats up some (smaller die PCH, does not)
                                          • always constant black screen no matter what's tried
                                          • no USB recognition
                                          • no HDMI output
                                          this is as far as I can get with it and not sure where to inspect next ?
                                          I tried...
                                          03-27-2024, 03:13 PM
