Sharp LC-46D64U TV voltage... both 110V and 220V?
  • ksufocus
    • Jun 2014
    • 8
    Question is will my Sharp LC-46D64U accept both 110 and 220V input?
    The back of my TV has the sticker than mentions 110V for north american and below has 100-240 for others. The manual also says the same thing, but I called Sharp and the lady I spoke to on the phone said they didn't recommend it... not sure though.
    Any advice would be great... Moving overseas and would like to not have to buy a voltage transformer...
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Sharp LC-46D64U TV voltage... both 110V and 220V?
    How about video standard?
    http://ihffilm.com/videostandard.html
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • ksufocus
      • Jun 2014
      • 8
      I'm not planning on receiving the "local" (foreign) signals thru cable/satelite... I would only be using it for streaming US TV over VPN, watching movies, playing video games.
      • ksufocus
        • Jun 2014
        • 8
        I'm attaching a page from the manual... see near the bottom. It references both 120V and 110-240V...
        • selldoor
          Slow Learner
          • 7870
          You would be better showing the picture of any info on the back of the tv.
          Also there may be more information or a jumper or wire link on the power supply board
          with an alternative position for different voltages.
          Hope your not going to brazil
          http://www.liveinbrazil.org/electric...en-travelling/
          • ksufocus
            • Jun 2014
            • 8
            Picture of TV attached...
            Are you recommending that I open up the back of the TV to look at the power supply board?
            Nope not Brazil... Expat to Norway
            • selldoor
              Slow Learner
              • 7870
              Yes, as you said the label is as confusing as the manual. There may be something specific on the power supply board you would have thought the help desk could have given a definite response .
              • ksufocus
                • Jun 2014
                • 8
                Opened the back... here are a couple pictures of the power supply board. Looks like it's ok for 110-240V. Tried to google the board part number for specifications but all the sites I looked at didn't give anything I was looking for.
                • ksufocus
                  • Jun 2014
                  • 8
                  Another pic...
                  • selldoor
                    Slow Learner
                    • 7870
                    Id say the tick in the middle box is the clue. Sorry i dont have time now to check further
                    guess you searched for DC-2541-1A ?
                    Norway Eh - bit cooler than Texas? I have been a couple of times - last time was in Nov
                    last year on a hurtigruten coastal trip to try and see the "northern lights". Bit chilly and
                    jolly expensive - not that we spent much as all meals were included and we had a fairly
                    "dry" ten days. Didnt see a very good show of the lights so we may go again in January
                    • ksufocus
                      • Jun 2014
                      • 8
                      Yeah I googled the DC... number. Mostly Ebay and other sites selling used boards with no real information other that the TV model number it's compatible with.
                      Yep leaving for Norway in August, I'll be there 2-3 years. Seeing the northern lights is definitely on my list of things to do. But I hear it's sometimes hit or miss... and yes crazy expensive!
                        The TV should be fine. The only thing that won't work will be something like the tuner; the HDMI and component ports should still work as they are completely universal. Also, it will probably work with PAL sources as most modern TVs support PAL and NTSC, regardless of the region they are made for.
                          • 31198
                          have you got a foto of the psu?
                          it's worth checking what voltage the smoothing cap(s) are for a start.
                          they may have left parts out or used under-rated parts for the u.s. market.
                          btw, it probably wont be much use in norway unless you have a cable or sat reciever when you get there.
                          they use DVB and it's probably MP4 and HD.
                          if your tv can tune it, it may still need an MP4 cam module.
                          • skytrain
                            • Sep 2014
                            ksufocus,
                            were you able to verify whether or not the Sharp LC-46D64U TV works on 220V without a transformer?
                            Thank you.
                            • t4796
                              Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
                              by t4796
                              I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
                              Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
                              From the FAQ I learnt that for 110v the power...
                              10-25-2024, 06:59 PM
                            • maleksa
                              Yamaha SY85 power board 220v or 110v?
                              by maleksa
                              I need help to ascertain if the power supply on my Yamaha SY85 keyboard is 110v or 220v or both.
                              I have attached the schematics below....
                              07-01-2023, 08:49 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • sefoster
                              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                              by sefoster
                              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                              11-20-2022, 09:29 AM
                            • gavenb
                              Sharp LC-80LE661U 80 inch
                              by gavenb
                              Hi folks!
                              I have a LC-80LE661U that had some interesting issues.
                              Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                              I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                              11-12-2023, 02:05 PM
