I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
From the FAQ I learnt that for 110v the power supply doubles the voltage with the two diodes and caps. In 220v operation there are two additional diodes and a wire link is removed.
I see the mains filter capacitors but not a lot else. Fuse is blown. Is it safe to assume after seeing 220v the 200v capacitors are toast? Whilst paired one looks taller with less of its wrapper overlapping the top so I think it might have vented.
Is there anything else obvious I should check which would have been damaged by the wrong line voltage? Would some components down the line have seen 440v potentially for a short time or are these power supplies designed to blow the fuse before that happen?
Thanks for any input.
 no audio out of the instrument channel, but some weirdness is gone and sounds now clean on the second channel. So I put my laptop on there and cranked the music full tilt. Sure enough, it goes crackle and pop with the bass in rhythm. Put my signal geni on it and sure...
