Sony KDL-32EX340 not powering on
    Re: Sony KDL-32EX340 not powering on
    That is means the PFC is working and the STBY power supply is also working since the VCC for the PFC IC is from one of the winding output of the standby power supply. I think he need to choose which board to work on first, the old one with dead STBY, or this one with PFC and standby working, also since he indicated that the 380V on the cap drops down, then he needs to verify that it is not due to PS_ON drop off.
    The small red circle is after the fusible resistor R6536 that feeds the B+ from the + of the main filter cap to the two power MOSFET for the 12V-24v SMPS section.
    BTW, that big SMD IC in the primary side is the PFC Controller and SMPS IC all in one.
    • OldMan
      • Jun 2011
      • 47
      Originally posted by bammbammfran
      looks like he is getting the 380 between neg of main cap pin (yellow) and the small red circle w/ + next to it on the main power mosfet
      This is correct. Main cap is a steady 164V.
      What can I conclude from this pertaining only to the newest board which doesn't show open with respect to pin 7 of the IC? I'm pretty much stumped and the shop I bought the board from stands by their word of testing the board prior to shipping.
        You should be getting 380V on the large red circle also since those two red circles are connected through very low Ohms fusible resistor R6536.
        • bammbammfran
          • Apr 2014
          • 476
          I agree that the voltage at the main cap and power mosfet pin should be basically identical since the white resistor is only .1ohms
          Discharge the board again and Try checking that white rectangular resistor
          also while checking resistance
          check the red circled pin versus the black circled pins on the capacitor that I had you check for 12 volts
          • selldoor
            Slow Learner
            • 7870
            Lost me several times! I did ask him to choose a board to work on and ONLY
            refer to that in the thread.
            I think given that you at least have standby on the new board going forward
            ONLY work on that and try to establish if the mainboard is working ok.
            Which I believe is what Budm is saying.
            • OldMan
              • Jun 2011
              • 47
              Ok, focusing only on the new board as this seems to have fewest issues.
              Budm, what large red circle should have 380V in your picture? I can test but don't want to test wrong spot and short something. Imagine I keep negative on the negative of the big cap still?
              Bamm, no resistance on the 12v cap
                Just measure right at the two legs of the big filter cap when TV is plugged in and when the power switch is activated.
                When measure the voltage on the secondary side you will use chassis ground as the ground ref point such as the 5VSTBY, 12V output on the secondary side. When work in the primary side, the negative leg of the main filter cap is the ground ref point.
                • bammbammfran
                  • Apr 2014
                  • 476
                  NO resistance on the cap OR shows as Zero ?
                  It should build up resistance, or if partly charged may drop and then raise back up
                  If Zero, it is shorted at the rectifier diode
                  If not showing Zero, and if using a manual select tester, raise up to the next ohm setting
                  • renee
                    • Jun 2010
                    • 21
                    #29
                    please help me to find volts PRI_VCC on C6206 sony G6 power supply
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • delpiero3
                      Sony Vaio SVS MBX-261 board failure
                      by delpiero3
                      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                      Nevertheless, let's say, i don't come as a total beginner.
                      I have this old laptop, which suit perfectly my needs, with the...
                      10-29-2024, 06:16 AM
