Westinghouse LD-4680 - no power - seems to be stuck in stanby
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Westinghouse LD-4680 - no power - seems to be stuck in stanby
    Simply re-positioning that strip that is above the LED strip made it go away. So all is well here now. Thanks again for all the help.
      Good repair and thanks for the follow-up.
      • tibimakai
        • Jan 2012
        • 3680
        Sorry, I couldn't help. I was at Disneyland in Orlando.
        The last problem it happened to me too. I have cut to much, from the side of the ribbon and then the ribbon it's off to one side.
        Usually I remove the panel completely(if you have to cut to much from the ribbon's length) and I re-position the two ribbons, to reach to the LED strips.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          Originally posted by Dgtech
          I powered up, the lights came on. I'm looking at it from backside with the unit face down on my work desk. I put it all back together and start to program channels to find another problem. LOL
          I'm wondering if maybe I can loosen up a screw that maybe I over tightened for the clip that holds the panel in.
          Either that, or maybe I didn't put the ribbon into the connector quite right. I will try a little later.
          Thanks for all who chipped in. Any suggestions for this issue? Anyone correct this before?
          FROM POST #19 -
          The darkness in the picture was caused by the ribbon strip not completely connecting at the connector. I had to take this apart again to redo the tape repair as well as reposition the ribbon in the connector. I'm satisfied with the results so far. I may just keep this set (46) and sell my Samsung (42)
          • tibimakai
            • Jan 2012
            • 3680
            You have to be careful, when trimming the width of the ribbon. If you trim to much, it can slide sideways and make wrong contact or not at all.
            • Ifixstuff9
              Westinghouse LD-4285 stuck in stanby, short on mainboard?
              by Ifixstuff9
              When the TV is plugged in the red standby LED comes on and nothing else... it won't respond to any of the buttons. I don't get any other signs of life from the TV.
              I know that a few similar Westinghouse models had an issue where the backlight ribbon cables would short out against the LCD frame, but I have tried turning it on with the backlight ribbons disconnected and nothing changes. I also partially disassembled the panel to inspect the ribbons and they look fine, I even added some electrical tape to insulate them from the frame just to be safe.
              This TV has just...
              04-25-2021, 09:19 PM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • stormanimal83
              Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
              by stormanimal83
              Hey....
              Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
              my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
              01-18-2024, 02:15 PM
            • ekozeko333
              [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
              by ekozeko333
              I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
              🔥 The Problem Started After Suspected ESD/PD Fault
              I experienced a power issue or ESD event through a USB-C charger
              After that, the NX20P5090 power switch was visibly burned and was replaced
              Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
              🧠 What I’ve Done So Far
              Flashed...
              06-21-2025, 02:48 AM
            • praveenramavath
              Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
              by praveenramavath
              Hello All,
              I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
              https://www.hifivision.com/threads/m...-screen.98243/
              Troubleshooting Summary: Majority Internet Radio - Flash Chip
              04-26-2025, 09:08 AM
