Philips 55 oled 804/12 red light blink
  • Diah
    • Feb 2013
    • 6650
    leave it at factory mode, and play color pictures... this i cant see well..
    one things more the joystick key control of the TV are downside at the middle??? if so.. mean you are placing the TV on it... and it pressed always .. this why when you play the file of remove error detect from T-CON your TV go to Recovery mode..
    after you play color photos ... you need to first to exit Factory mode FAC_OFF file... then play the other to remove the protect.. after you examine the keys control didn't pressed
    • djordje
      • Nov 2015
      • 39
      • Serbia
      The joystick key control is on the back cover and it is removed from tv so it isnt pressed.
      When i run only .eed file with remove error from T-CON i only get black screen with red light blinking.
      Will try different color pictures in factory mode and post it here.
      • djordje
        • Nov 2015
        • 39
        • Serbia
        Here is what i got after playing color picture.
        As you can see on pictures there is a line of bad pixels going between letter F and A and also there are lines going over word MODE. I didnt take whole picture of screen because this was only weird spot on screen.
        Also i have tried to play some video but picture was not that good as it is supposted to be. Maybe i am not able to get full resolution while i am in factory mode?
        After i was done with factory mode i have run usb with factory mode off.eed and i was prompted in android recovery screen. Then i used T-CON remove error .eed but after that i only get black screen and blinking red light.
        • djordje
          • Nov 2015
          • 39
          • Serbia
          I couldnt sit in place waiting for help i just needed to try some things on my own.
          I have cleaned and refited all connectors. And after that i have tried one more time to run nvm files.
          First i ran factory mode on.eed and there were no lines that i talked about in my previous post. After that i ran factory mode off and the tv came on.
          Was suprised that is this possible. Also i have tried to play some video and picture was good. Checked also with color picture and there are no lines.
          So my question is what is best way to test it and see if will go in some protection again. And also should i update it to latest software version via tv menu?
          Thank you for help
          • Diah
            • Feb 2013
            • 6650
            Thank you for help
            glad to hear this ... no need to play or test any things... just use it as normal TV... enjoy
            • djordje
              • Nov 2015
              • 39
              • Serbia
              #26
              Thanks Diah for your help
              • djordje
                • Nov 2015
                • 39
                • Serbia
                #27
                Hello, its me again
                I didnt have much time to test tv these days it was just half hour or 1 hour of watching but last night i watched tv for 3 hours and this is what happened.
                In one moment tv started blinking like on-off really fast and it was repeating more and more. First it was just a blink and then pause of few minutes but after that it was more often. When it sudendly off. And again same blinking pattern as before with black screen.
                After that i tried same NVM files but i didnt get any indicator light on TV. So i left it for 1 hour and after that i run NVM files and TV started again but this time took only 10 minutes before going off again.
                Is there some thermal shutdown protection for this TV?
                Maybe i should change some thermal paste on ICs because there is no light on indicator until TV cools down. Or power supply is not working properly after running.
                • Diah
                  • Feb 2013
                  • 6650
                  i never heard issue before as yours description .. check yours wall outlet socket.. or the PSU downside if there are crack bad joint solder.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4658
                    • Italy - Milan
                    #29
                    Same common missing of particulars in description, i feel great confusion between blinking status led / screen / sound..
                    "thermal paste" ? These are boys solutions, today faults are not simple and not for DIY, you probably have BGA problems somewhere, my advice, if tthere are serious repair labs and you have money to spend, give them a chance.. bye..
                    • djordje
                      • Nov 2015
                      • 39
                      • Serbia
                      #30
                      First i thought that i had some MB issue because screen was turning off. But as Diah said in last post maybe it was PSU. So i checked it visualy from both sides but i couldnt see cracks or bullged caps, so idea was to recap it anyway and now TV is working for several hours. Hope that this is reason why TV was not working.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4658
                        • Italy - Milan
                        #31
                        No that is not the reason... my bet..
                        • Diah
                          • Feb 2013
                          • 6650
                          go bet on soccer not on TV
                          keep using it as normal TV and enjoy it
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4658
                            • Italy - Milan
                            #33
                            You poor loose again, your advices didn't changed a comma, as always, so shut up, it's better for you..
                            • bohaboha
                              • Nov 2012
                              • 1108
                              • sweden
                              #34
                              You really encourage People to try .just fantastic
                              • Diah
                                • Feb 2013
                                • 6650
                                you should shut up,, you cant release what we are doing here... we give files no one can have access to them... if you remain in fucking ass i will stop upload any professional files over here unless admin tear you down... so rubbish this site become of such kind boys.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4658
                                  • Italy - Milan
                                  #36
                                  you are provoke as usual, you are the king of nothing, here and surely alsewhere, fly low.. and don't use vulgar expressions, we are in a reputable place..
                                  • nomoresonys
                                    • 12370
                                    • U.S.
                                    #37
                                    Well done, good decision to recap, MOST of the time in my observations, when its fine for a while then does as you described as in stays on for shorter periods. Then more often than not it's a cap issue.
                                    • nomoresonys
                                      • 12370
                                      • U.S.
                                      #38
                                      If enough members report the first RUDE comment, then maybe someone in charge will clean up the trash around here. I think it was post # 29 and reported it AND will continue to do so. I don't think I am the only one FED UP with these antics.
                                      • bohaboha
                                        • Nov 2012
                                        • 1108
                                        • sweden
                                        #39
                                        please how to report i do not find how thank you
                                        • nomoresonys
                                          • 12370
                                          • U.S.
                                          #40
                                          Right below there where it says quote and flag, click flag and give a brief reason you think it is offensive or provoking or whatever you think is wrong.
                                          • Chris24
                                            LG OLED77C2PUA CUSQLJR Does not turn on - solid standby light with one blink.
                                            by Chris24
                                            Hello, been a while since posting and always appreciate this forum and the help.
                                            Picked up an LG OLED77C2PUA that does not turn on.
                                            The standby light does come on when plugged in. Pressing the on/off button on TV (or LG remote) the red light turns off for 1 second and comes back on steady. I took off the back panel and tested the power supply. When pressing the power button, the 20V and 12V to Mainboard spike to 19.9 and 11.9 for a few seconds then slowly drop back off. Can tell the supply is coming on for 2-3 seconds. The 12V to TCON also spikes to 11.9 then drops back...
                                            01-27-2026, 12:03 PM
                                          • Diah
                                            Guide : Philips OLED TVs how to remove the protection mode NVM.EED
                                            by Diah
                                            OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
                                            not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
                                            Philips OLED TVs. we can switch the protection code to off via binary.
                                            - ropy it on empty usb stick and insert it while the tv off at USB 1
                                            -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the...
                                            04-21-2024, 03:21 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
                                          • Boardview and Schematic Bot
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
