Philips 55 oled 804/12 red light blink
    replied
    Right below there where it says quote and flag, click flag and give a brief reason you think it is offensive or provoking or whatever you think is wrong.
  • bohaboha
    replied
    Originally posted by nomoresonys View Post
    If enough members report the first RUDE comment, then maybe someone in charge will clean up the trash around here. I think it was post # 29 and reported it AND will continue to do so. I don't think I am the only one FED UP with these antics.
    please how to report i do not find how thank you
    replied
    replied
    Well done, good decision to recap, MOST of the time in my observations, when its fine for a while then does as you described as in stays on for shorter periods. Then more often than not it's a cap issue.
  • Davi.p
    replied
    you are provoke as usual, you are the king of nothing, here and surely alsewhere, fly low.. and don't use vulgar expressions, we are in a reputable place..
  • Diah
    replied
    Originally posted by Davi.p View Post
    You poor loose again, your advices didn't changed a comma, as always, so shut up, it's better for you..
    you should shut up,, you cant release what we are doing here... we give files no one can have access to them... if you remain in fucking ass i will stop upload any professional files over here unless admin tear you down... so rubbish this site become of such kind boys.
  • bohaboha
    replied
    Same common missing of particulars in description, i feel great confusion between blinking status led / screen / sound..
    "thermal paste" ? These are boys solutions, today faults are not simple and not for DIY, you probably have BGA problems somewhere, my advice, if tthere are serious repair labs and you have money to spend, give them a chance.. bye..
    You really encourage People to try .just fantastic
  • Davi.p
    replied
  • Diah
    replied
    No that is not the reason... my bet..
    go bet on soccer not on TV
    Originally posted by djordje View Post
    First i thought that i had some MB issue because screen was turning off. But as Diah said in last post maybe it was PSU. So i checked it visualy from both sides but i couldnt see cracks or bullged caps, so idea was to recap it anyway and now TV is working for several hours. Hope that this is reason why TV was not working.
    keep using it as normal TV and enjoy it
  • Davi.p
    replied
  • djordje
    replied
  • Davi.p
    replied
  • Diah
    replied
    i never heard issue before as yours description .. check yours wall outlet socket.. or the PSU downside if there are crack bad joint solder.
  • djordje
    replied
    Hello, its me again
    I didnt have much time to test tv these days it was just half hour or 1 hour of watching but last night i watched tv for 3 hours and this is what happened.
    In one moment tv started blinking like on-off really fast and it was repeating more and more. First it was just a blink and then pause of few minutes but after that it was more often. When it sudendly off. And again same blinking pattern as before with black screen.
    After that i tried same NVM files but i didnt get any indicator light on TV. So i left it for 1 hour and after that i run NVM files and TV started again but this time took only 10 minutes before going off again.
    Is there some thermal shutdown protection for this TV?
    Maybe i should change some thermal paste on ICs because there is no light on indicator until TV cools down. Or power supply is not working properly after running.
  • djordje
    replied
    Thanks Diah for your help
  • Diah
    replied
    I couldnt sit in place waiting for help i just needed to try some things on my own.
    I have cleaned and refited all connectors. And after that i have tried one more time to run nvm files.
    First i ran factory mode on.eed and there were no lines that i talked about in my previous post. After that i ran factory mode off and the tv came on.
    Was suprised that is this possible. Also i have tried to play some video and picture was good. Checked also with color picture and there are no lines.
    So my question is what is best way to test it and see if will go in some protection again. And also should i update it to latest software version via tv menu?
    Thank you for help
    glad to hear this ... no need to play or test any things... just use it as normal TV... enjoy
  • djordje
    replied
    Thank you for help
  • djordje
    replied
    Here is what i got after playing color picture.
    As you can see on pictures there is a line of bad pixels going between letter F and A and also there are lines going over word MODE. I didnt take whole picture of screen because this was only weird spot on screen.
    Also i have tried to play some video but picture was not that good as it is supposted to be. Maybe i am not able to get full resolution while i am in factory mode?
    After i was done with factory mode i have run usb with factory mode off.eed and i was prompted in android recovery screen. Then i used T-CON remove error .eed but after that i only get black screen and blinking red light.
  • djordje
    replied
    The joystick key control is on the back cover and it is removed from tv so it isnt pressed.
    When i run only .eed file with remove error from T-CON i only get black screen with red light blinking.
    Will try different color pictures in factory mode and post it here.
  • Diah
    replied
    leave it at factory mode, and play color pictures... this i cant see well..
    one things more the joystick key control of the TV are downside at the middle??? if so.. mean you are placing the TV on it... and it pressed always .. this why when you play the file of remove error detect from T-CON your TV go to Recovery mode..
    after you play color photos ... you need to first to exit Factory mode FAC_OFF file... then play the other to remove the protect.. after you examine the keys control didn't pressed
