Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • bohaboha
    • Nov 2012
    • 972
    • sweden
    Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
    anyhow i couldn't t read anything else
    the backlight is on strong and the screen does not get dark or very dark but no pictures
    the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
    any idea please help
    am having problem to uppload som pictures
  • Answer selected by bohaboha at 01-12-2025, 06:01 AM.
    bohaboha
    • Nov 2012
    • 972
    • sweden
    Originally posted by apokalipto
    You can activate pmic voltages shorting trdy1&3 test points, for this test you must disconnect lvds cable.
    thank you i ll try if i find those test points quite difficult to se any inscription
    • Davi.p
      • Sep 2009
      • 4271
      • Italy - Milan
      Samsung horse s**t, same as most of them, you can think about bad screen, or something very exotic else but the end is more or less not fixable , someone tries with ribbon cable pins masking but it's not professional solution, may it last some weeks, some months or?
        • 12084
        • U.S.
        Start with a simple reset, unplug all cables from tv, unplug tv from power>press and hold power button on tv for 45 seconds>wait 2 minutes>plug tv into wall outlet and try it. If no joy, troubleshooting usually starts with checking voltages at powerboard. Tampatec explains it here for those that may need it, otherwise what are your voltages there: https://www.youtube.com/watch?v=XH9GfkGQX1I
          • 12084
          • U.S.
          Also see if your optical light is lit on mainboard.
          • Storyteller12
            • Jun 2020
            • 624
            I agree, seems like all you need to be a TV technician these days is a roll for scotch tape. lol
            • bohaboha
              • Nov 2012
              • 972
              • sweden
              Yes Samsung today.
              You really think bad Screen? the main board get a bit hot can be a direction .sorry i try to upload some pictures no success
              Thank you so long
                • 12084
                • U.S.
                Well you can do a little testing or you can ASSUME, your call.
                • bohaboha
                  • Nov 2012
                  • 972
                  • sweden
                  Hello and thank you it is very difficult to read what it says on this BN44-01056A but 400V on the main capacitor on the CNM801 connector 13.08v on the top part and 3.08v and 3.872h on the bottom part
                  those values are on the main board and the optical light is lit on the main board
                  please try to se if you can read a thing on BN44-01056A​
                    • 12084
                    • U.S.
                    https://www.shopjimmy.com/samsung-bn...ply-led-board/
                      • 12084
                      • U.S.
                      Go ahead and check all the diodes on top of the board, tv UNPLUGGED, meter in doide mode, expect .3 to ~.7, reverse meter leads for ol or 1.
                      • bohaboha
                        • Nov 2012
                        • 972
                        • sweden
                        Thank you for the link for the Diode Reading from right to left 0.691, NR ,0535, NR,1.7, NR ,1.5, NR all the reads are downgrading no reads are no reads from both side
                        just for information those diode had a big voltage of 188v when i test them in my previous post is it normal in the cool side?
                        thank you for helping me
                        • Diah
                          • Feb 2013
                          • 6343
                          i just read here Temperature messing and issue describing.... no photos at all... i did solved same issue on 75 size,,, this 70 i don't know if its same conflagration... so please upload clear photo on yours tv whole back and yours MB
                          • bohaboha
                            • Nov 2012
                            • 972
                            • sweden
                            You are welcome Happy new year i start mine with big problem to upload pictures on my windows so i do not get access to my pics i ll try to find a way to fix it just give a bit of time
                            • Davi.p
                              • Sep 2009
                              • 4271
                              • Italy - Milan
                              I don't want to go much ahead with these discussions, i can't say it is the panel 100% , on some models there are failing caps.or diodes in the panel strip boards, this is the hope for you as you can fully restore it, then i want only to express again, how it is light years far watching at a power supply at this type of issue, i only want to say this example to lift you from unuseful tests, when i was troubleshooting my Samsung in the previous month, i also provided power to the chain MB+lcd with a tested atx power supply, no differences! 20A 12v! There is only a secret to reveal for me, how does these tv manages the informations stored in the panel spi flash, since deleting it changes no things.. it's hard to understand,, you can read other topics on how to find and troubleshoot these common issues, last thing, i read last week a Samsung document, where they says they sells panels that came out of production with defects, then they repair short circuits with the use of laser and a special circuit design, this lets me think that those fix are not so durable, but this does not explain well how certain panels produces many bad lines at a time, i read that a portion of the panels are organic substance, also this is a clue that them can vary the working state with age..
                              • bohaboha
                                • Nov 2012
                                • 972
                                • sweden
                                hey bro you didn't want deep but here you were really in the darkest deep ocean you might be right but try doesn't hurt and you learn something or how and in the end it's just a repair
                                • Davi.p
                                  • Sep 2009
                                  • 4271
                                  • Italy - Milan
                                  i understand nothing, if you have complaints about me, bye bye!
                                  • bohaboha
                                    • Nov 2012
                                    • 972
                                    • sweden
                                    did i complaint ? no just try to understand
                                    • bohaboha
                                      • Nov 2012
                                      • 972
                                      • sweden
                                      ok here are some pics hope they are good
                                        • 12084
                                        • U.S.
                                        Seems like an odd reading, I would lift/unsolder one leg of the one reading 1.7 and retest out of circuit.
                                        • Diah
                                          • Feb 2013
                                          • 6343
                                          you have U ribbon cable one on each side at the middle of the panel buffer boards.. try disconnect one a time.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • stinger
                                            Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                            by stinger
                                            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                            04-17-2024, 03:06 PM
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
