Funai LF320FX4F Power Supply Issue?
  • toxicmonkeylove
    • Nov 2011
    #41
    Re: Funai LF320FX4F Power Supply Issue?
    hello I have the same problem only mine is a magnavox 32me303v/f7 which is the same just branded as magnavox. when powered on the stand-by led blinks 20X at the 12th blink it flashes the word magnavox on the screen. The 21v p on signal when the set is turned on is 21v after the led stops blinking(and stay's lit) the voltage goes to 11v . the amp 13v signal goes from 13v down to 6.5v. The all 3.3v signal stay's at the voltage 3.3v. this is how far i have gone with it. replace both boards still the same problem
    • slymaster
      • Mar 2014
      • 7
      • usa
      #42
      If u replaced both boards and still the same problem.then most likely its the LED backlights at fault.
      • Capacitor_King
        • Jul 2015
        • 5
        I was given one of these Funai LF32FX4F TV's
        I replaced most of the capacitors on the board (Except for the main big one and the two really small ones) and the set still has the same problem.
        It powers on just long enough to see the Funai logo and then shuts down.
        I did not test voltages but I did unplug the LED strip and it still does the same thing (I pointed a bright flashlight at the screen, and I was able to see the Funai logo just before the unit shut down)
        What else can the problem be?
        PS: I am a new member to the forum and also new to board level electronics repair, I only decided to try and repair this power supply board because buying a $54 board for a $100 TV does not make sense to me
        • chazzmcc3
          • Jul 2015
          Originally posted by BOROSS
          I have a lf320fx4f also but mine makes a high pitch whinning noise when I plug it in and nothing happens when I push the power button. what would make that noise?
          I am having the exact same issue. Did it end up being the main board or the power supply?
          • genewood
            • Aug 2015
            I have had several of these with the same problem. Shuts off after the splash screen. Could be Magnavox,Emerson or others made by Funai. Don't know what the exact cause is but they are easily fixed by increasing the value of C1006.
            You need about 470uf /100 volts to be on the safe side.Due to size I usually don't try to mount it on the board just have some wires from under the board.
            Plenty of room adjacent to the board.
            • jimmyk
              • Sep 2012
              did you ever find a solution ? I have two of these with the same symptoms. Squeal , no led nothing but the squeal.Disconnect from main and the squeal stops.
              • artstv1
                artstv1
                • Sep 2014
                • 10
                • sarasota
                #47
                This funai model has a problem with bad L E D,s . remove the front excushion and replace or jump bad one. it is not hard just time consuming. common prob.
                • fixerupper75
                  • Oct 2014
                  • 125
                  • us
                  #48
                  Had the same issue with flashing of the name for 2 seconds. I replaced the c1006 with 470uf 100v and the tv is now working. Does anyone no why this is?
                    C1006, C1007 are connected in parallel, they are the filter caps for the boost converter to produce the drive Voltage for the LED string.
                    Did you measure the capacitance and the ESR of that cap.
                    Pictures provided by shopjimmy.
                    • fixerupper75
                      • Oct 2014
                      • 125
                      • us
                      #50
                      No i didn't but i did notice the voltage dropped to 10vdc with the 47uf 100v cap and with the 470uf 100v it dropped to 50vdc.
                        Since C1007 (same value cap) is in parallel with C1006, you might as well replace both of them at the same time with good quality low ESR type.
                        • fixerupper75
                          • Oct 2014
                          • 125
                          • us
                          #52
                          Already done!!!!
                          Maybe this will help next person with their Black Friday special!!!!
                          • ron350
                            • Feb 2014
                            • 296
                            OK C1006, C1007 are 47uF x 100v by 10mm x 12mm with 5mm lead spacing.
                            I think the largest caps that will fit are 12.5mm x 25mm with 5mm lead spacing.
                            What would be the best caps to use that will fit vertically?
                              What is the height of tallest cap on that board?
                              • ron350
                                • Feb 2014
                                • 296
                                Hi Budm the tallest cap on my boards are around 12mm.
                                I soldered a 12.5 x 25 in place of C1006 and put modeling clay on top and there is about 4mm vertical clearance under the plastic back cover.
                                The problem is there is not enough side room for two 12.5 mm caps so I guess that limits the size to 10mm x 25mm.
                                  So is the original cap is 47uF 100V? but in post 50 he put in 470uF 100V, that will be much bigger cap! something is not right.
                                  • ron350
                                    • Feb 2014
                                    • 296
                                    That is why I am asking what would be a good quality replacement of a higher value in a 10 mm x 25mm can.
                                    The original C1006, C1007 caps on my board are Su'scon SL 47uF x 100v 85*.
                                    • ZnsaneRyder
                                      • Oct 2015
                                      • 88
                                      • Merica
                                      #58
                                      I am fixing this same TV with the same issue.
                                      Originally no backlight, and just the Funai logo come on for split second.
                                      I replaced the 2X 47uf caps with 1 47uf/160V and 1 150uf/100V in parallel, and the backlight and Funai logo will come on for a split second, then the set shuts off. The 12.5mm caps will fit if you bend the legs over a bit first.
                                      Also tried adding a 470uf cap, only difference is it flickered on twice, but still shut off. Also tried different mosfet and diode on the boost circuit, same issue.
                                      So upgrading caps only allowed it to come on, but not fix issue.
                                      • ZnsaneRyder
                                        • Oct 2015
                                        • 88
                                        • Merica
                                        #59
                                        I opened the LCD part of the TV to discover a single blown LED backlight. All the others work, which is why I thought when testing that they were good. Just the one in the center is blown.
                                        These TV's must be sensitive to slight voltage variation of LED, but I wish it didn't shut off the whole set. I wanted to post in case others deal with this TV. I'm guessing the capacitors helped by making the LED voltage stronger, being one is blown or about to blow, it draws more current.
                                        • ZnsaneRyder
                                          • Oct 2015
                                          • 88
                                          • Merica
                                          #60
                                          I replaced the LED and the TV lights. Now I just need to find the right LED to replace it.
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
