42PJ350 clicking noise
  • sordids999
    • May 2013
    • 2152
    #41
    Re: 42PJ350 clicking noise
    whats the EAX/EBR number for your zsus i have one thats working if tom says its your zsus
    • marty-clubber
      • Oct 2014
      • 58
      • u k
      #42
      Ysus board mate I have the same tv up stairs put the ysus board in working fine
      cheers any way.
      • marty-clubber
        • Oct 2014
        • 58
        • u k
        #43
        Hi tom
        both probes on resistor 00.1 hold few seconds go to 00.0.
          Well, ok...
          I SUPPOSE they could be bad...
          I would be personally surprised, but if you like, try swapping them.
          2.2 ohm 5%, 1W or 2W rated, flameproof/NOX type.
          • marty-clubber
            • Oct 2014
            • 58
            • u k
            #45
            Ok
            Tom Just order some new resistors post back let you know, personally don't think it going fix it! worth a shot.
            Have the same TV up stairs that how i know ysus board Faulty
            could i test most of the circuits on the good board to the faulty board in circuit?
            Thanks tom you been really helpful
            excellent site.
            • Amraks
              • Nov 2011
              • 725
              which location on the Y-SUS are these located and are these tested in circuit?
              • marty-clubber
                • Oct 2014
                • 58
                • u k
                #47
                Location
                R607,R729,R503
                No they been removed mate
                • Amraks
                  • Nov 2011
                  • 725
                  Cool I just wanted to know the locations just if I have this problem.
                  • marty-clubber
                    • Oct 2014
                    • 58
                    • u k
                    #49
                    Hi just updating changed 2x 30j124 2x 30f124 3 faulty resistors R607, R729, R503 Ysus board.Now the tv up and running
                    Thanks guys for all your help.
                    • del3165
                      • May 2014
                      • 24
                      • United Kingdom
                      #50
                      Decided to have another go at repairing this set. I was sure it was the power supply. I have changed most of the caps and the most common failing components except the 2 resistors which I checked out of circuit. I put 2 100watt bulbs on the output as per service manual and was going through the other tests when the bulbs came on. Reconnected the connector to the Y-sus board and the tv came on fine. Put the cover on and the tv started clicking again but comes on after about 10 min.
                      Is it usually a capacitor that would cause this ?
                      • del3165
                        • May 2014
                        • 24
                        • United Kingdom
                        #51
                        Changed another couple of caps on power board which tested fine out of circuit and looked ok. Tv now working fine.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #52
                          glad you managed to fix the set and all seems fine now but when you tested the caps off the board did you just test them with a capacitor meter or did you use a esr meter?
                          • del3165
                            • May 2014
                            • 24
                            • United Kingdom
                            #53
                            I used a fluke meter which can test capacitors. I retested the capacitors only one seemed very slow giving a reading. 3300uf read 3815uf.
                            • satinser
                              • Oct 2012
                              • 214
                              #54
                              I too have the same problem. I have also changed all the normal components that go faulty on this power supply. But despite all of this work the power supply still clicks and refuses to start. It is power supply related because it also clicks with no other boards connected when forcing the board to switch on.
                              I was interested to read the post by Del3165 regarding changing a few few capacitors that eventually resolved the fault. If your reading this post Del3165 I would be interested to know whether its still working ok and if so can you remember the which capacitor when changed cured the fault.
                              • del3165
                                • May 2014
                                • 24
                                • United Kingdom
                                #55
                                Tv working fine . I tried everything recommended before changing the caps. I changed all the caps apart from the 2 very large ones.
                                • satinser
                                  • Oct 2012
                                  • 214
                                  #56
                                  Glad to hear your TV is still working appreciate your reply
                                  • dhavalrpatil
                                    • Feb 2017
                                    • 11
                                    • india
                                    #57
                                    Hello i have same problem with 42pj350 supply just clicking. i replaced 3br1565 diode 304 but i got same result there is no vs va some time i switching it give vs va but after on off it agian clicking. Which caps u chaged will u tell me@ del3165 ?
                                    • NConstantinou
                                      HP Z840 workstation power supply clicking noise
                                      by NConstantinou
                                      No power
                                      i have the above ps which i change the TOP258eg ic.
                                      Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                                      i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                                      the colours look like R,R,W or silver,G Bl.
                                      Thanks...
                                      12-25-2024, 02:24 AM
                                    • tony359
                                      by tony359
                                      11-28-2023, 05:18 AM
                                    • MegaZAC
                                      Onkyo TX-SR805 noise in one channel
                                      by MegaZAC
                                      Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                      Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                      There's some logic behind it. As soon as I select an input I get only left...
                                      04-23-2025, 10:09 PM
                                    • courtcircuit
                                      Philips HTS8000 home cinema noise problem
                                      by courtcircuit
                                      Hello
                                      I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                      Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                      Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                      I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                      Removed each of tyhe boards
                                      02-08-2025, 08:22 AM
                                    • stormy90
                                      LG 42PJ350 Clicking PSU (TL;DR inside)
                                      by stormy90
                                      Hello!
                                      TL;DR: Replaced blown Q801, Q802 and fuse, but it didn't fix the problem.
                                      I'm trying to repair this TV, since it developed clicking symptom. I disconnected Y-SUS and Z-SUS boards, but PSU was still clicking, so then I was sure problem lies in PSU. When you plug it in, you can hear 2 clicks from relay and then one click when it shuts down. I found two shorted mosfets Q801, Q802 and blown fuse F801. I replaced those elements, but it's still doing the same.
                                      After some research, I found out resistors R108-113 need to be checked and sure one was showing...
                                      09-13-2020, 01:18 PM
